yes or no question
Old Jan 7, 2008 | 11:35 PM
iwantspeed's Avatar
Default yes or no question
just put my new distributor on and im curious to, if i leave the 3 bolts that hold the dizzy down loose when i first start the car incase i need to adjust the timing by moving the dizzy around a little. or should i have the dizzy tightend all the way down before i start the car.
thanks.
Old Jan 8, 2008 | 12:20 AM
STREETWERKZ's Avatar
Default Re: yes or no question (iwantspeed)
You didn't ask a, "yes or no question".
You should tighten the distributor and readjust as needed.
Old Jan 8, 2008 | 01:12 AM
killa rex's Avatar
You can tighten 1 bolt to hold it in place b4 u start the car. Then adjust as needed
Old Jan 8, 2008 | 07:09 AM
thesmogman's Avatar
Default Re: (killa rex)
Loosen the bottom two and leave the top one finger tight.
Old Jan 8, 2008 | 08:02 AM
iwantspeed's Avatar
Default Re: (thesmogman)
thanks guys
Old Jan 8, 2008 | 11:34 AM
iwantspeed's Avatar
Default Re: (iwantspeed)
ok so now theres a check engine light... wtf. and i have NO idea how to run codes.
Old Jan 8, 2008 | 11:43 AM
EF_generation's Avatar
Your ecu is under the carpet in the passengerside footwell, if its an 88 it'll have a little clear window on the front of the ecu count how many times it blinks if its one code it should look like this
. . . . . . . ._. . . . . . . ._. . . . . . . . Would be code 8 get it? Check a repair manual to see what it is
Old Jan 8, 2008 | 12:04 PM
iwantspeed's Avatar
Default Re: (EF_generation)
i have a b series swap. its a chipped p28 with no clear window on it.
Old Jan 8, 2008 | 12:33 PM
98lude-t's Avatar
did you remove the jumper wire?
Old Jan 8, 2008 | 12:36 PM
thesmogman's Avatar
Well you would need to jumper the Service/timing connector and turn the key to the on position and watch the Check Engine Light. It will do the blinking. This is for OBDI. I am not sure what the P28 is, I believe it is OBDI.
Old Jan 8, 2008 | 12:38 PM
iwantspeed's Avatar
i know i have to use like a paperclip and connect 2 wires. just dont know what 2 wires. this guy told me to ask u guys for the pin out sheet or sumthin? ANYONE know what that means?
Old Jan 8, 2008 | 12:44 PM
thesmogman's Avatar
He is looking for a wiring diagram to see where the service connector wires hook up to the ECU. Sorry I don't have that.
That is the thing...it could of been stuffed around by the ECU or the kick panel. Look around there for a weird two pin connector (I believe it is gray) or a yellow rubber cover that covers two connectors.
Old Jan 8, 2008 | 12:51 PM
iwantspeed's Avatar
there is a clip down there with nuthing going to it.. ill take a pic.
im holding the thing i THINK your talking about in this one
Modified by iwantspeed at 2:06 PM 1/8/2008
Old Jan 8, 2008 | 12:57 PM
The jumper connector iz near the left front shock tower 90 and up have them near the ecu its a connecter that goes to nothin
Old Jan 8, 2008 | 01:06 PM
iwantspeed's Avatar
does that look like the thing?
Old Jan 8, 2008 | 01:18 PM
thesmogman's Avatar
Yes. It does.
Old Jan 8, 2008 | 01:21 PM
HOLY ELECTRICAL TAPE?!?!?!?!?!?
Did you "make" your own jumper harness. . . .my first wiring job was a mess too. . . . .I'm pretty sure that's not it cuz if it was in the wheel well it wud be to the right and away from the ecu try the left front shock tower
Old Jan 8, 2008 | 01:28 PM
iwantspeed's Avatar
theres a clip that looks very similar to the one im holding in that pic under my hood drivers side. but i thought it went to like a light or sumthing.
Old Jan 8, 2008 | 01:55 PM
thesmogman's Avatar
Hmm. well..a.... I would go for the one under the hood as that is where a 90ish should be. You can never tell when the word swap is involved.
Is it the one in front of the drivers side strut tower by the motor mount? That is it.
Old Jan 8, 2008 | 02:45 PM
iwantspeed's Avatar
ill try that and see if anything happens
Old Jan 8, 2008 | 03:14 PM
Tippyman's Avatar
It should be in the passenger kickwell near the glovebox.
Old Jan 8, 2008 | 07:45 PM
iwantspeed's Avatar
Default Re: (Tippyman)
how come its not in 1 spot? wouldnt it be the same on every car?? i did the one under the hood and nuthing happened. so i dont think thats it.. and im kinda worried just connecting wires on random **** so please help me figure this out!! lol maybe the kid that wired my motor put the clip i took a pic of in a easy spot to read codes and thats why its right by the ecu? can someone find a pic of the right clip? i feel so dumb right now for asking this.
Old Jan 8, 2008 | 08:54 PM
Bjorn20's Avatar
maybe.....
have the bolts loose enough that you can move the distributor by hand, adjust as needed and tighten them up.
Old Jan 9, 2008 | 07:32 AM
iwantspeed's Avatar
Default Re: yes or no question (Bjorn20)
guess your all done helpin me huh. lol thanks.
Old Jan 9, 2008 | 07:47 AM
thesmogman's Avatar
I guess my last post didn't make it. I did try to tell you that I was leaving and I would check back in tomorrow.
Since we don't know what was done it is hard to tell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">Hmm. well..a.... I would go for the one under the hood as that is where a 90ish should be. You can never tell when the word swap is involved.
Is it the one in front of the drivers side strut tower by the motor mount? That is it.</TD></TR></TABLE>
So try to find the wiring diagram for the P28 and then find the service connector pins from the ecu. Then we can just do it from there.
allisonmo2
Oct 7, 2008 05:40 PM
iwantspeed
Jan 15, 2008 06:51 PM
egmatt93
Nov 27, 2006 12:38 PM
HGZ
Oct 10, 2006 03:01 PM
Fuster_Cluck
10
Feb 24, 2005 09:58 AM
