All crx head come and help car wont rev past 4500 HELP!!!!!!!!!!!!!!
Old Jan 7, 2008 | 09:13 PM
nipcup101's Avatar
Default All crx head come and help car wont rev past 4500 HELP!!!!!!!!!!!!!!
ok i just converted my car to obd 1 and now im having drama only thing different i did was put some of my friends 108 i have a chipped ecu on crome and its not throwing anycodes or checkengine lights but wont rev past 4500 i put a stock p28 in there and it throws codes but it lets me rev it but no vtec i aint feeling it was running fine until the gas but i dont think thats the problem engine is a LSvtec oversized JDM itr pistons stock b16 head HELP!!!!!! NO TIME FOR PERIOD CRY .
Old Jan 7, 2008 | 09:18 PM
STREETWERKZ's Avatar
Default Re: All crx head come and help car wont rev past 4500 HELP!!!!!!!!!!!!!! (nipcup101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nipcup101 &raquo;</TD></TR><TR><TD CLASS="quote">ok i just converted my car to obd 1 and now im having drama only thing different i did was put some of my friends 108 i have a chipped ecu on crome and its not throwing anycodes or checkengine lights but wont rev past 4500 i put a stock p28 in there and it throws codes but it lets me rev it but no vtec i aint feeling it was running fine until the gas but i dont think thats the problem engine is a LSvtec oversized JDM itr pistons stock b16 head HELP!!!!!! NO TIME FOR PERIOD CRY .</TD></TR></TABLE>
i'm trying to decipher that run-on sentence.
108 octane?
when you put the p28 in the car, it throws codes? well.... what codes are you reading?
4500rpm is usually limp-mode and could be a number of reasons why. most common is due to spark/distributor.
when you say, "i just converted my car to obd 1 and now im having drama" does that mean your car has ran terrible since the obd-0 to obd-1 swap. or it only started acting up when you put the 108 octane in the car?
Old Jan 7, 2008 | 09:21 PM
nipcup101's Avatar
Default Re: All crx head come and help car wont rev past 4500 HELP!!!!!!!!!!!!!! (STREETWERKZ)
I'm going back out there and check again. Sorry for the run on i couldn't help it i just ran inside really quick.
Old Jan 7, 2008 | 09:23 PM
nipcup101's Avatar
car was pinging thats why i used the gas didnt think it would after me that much its 2 long pauses i remember that much and ima go check the others right now
Old Jan 7, 2008 | 09:25 PM
your car shouldnt ping with the build you described. adding 108 octane isnt going to fix a problem either.
my guess would be spark/dizzy related, weak spark or bad rotor.
Old Jan 7, 2008 | 09:31 PM
nipcup101's Avatar
4 long pause and 1 fast one , and 2 long pause
Old Jan 7, 2008 | 09:32 PM
nipcup101's Avatar
motor is fine it only has 130 miles on it was running fine obd 0 maybe plugs wires or dizzy possible
Old Jan 7, 2008 | 09:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nipcup101 &raquo;</TD></TR><TR><TD CLASS="quote">4 long pause and 1 fast one , and 2 long pause </TD></TR></TABLE>
41 Primary oxygen sensor heater - probably cause for the pinging.
20 Electrical load detector - cause for the 4500 limp mode + pinging.
you did switch to a 4 wire o2 sensor when doing the obd-1 conversion, right?
nipcup101's Avatar
o u said rotor hahah my fault
Old Jan 7, 2008 | 09:36 PM
nipcup101's Avatar
Yup I changed it but i used the rywire harness, and the wires they wanted ran didn't match up so maybe its mixed up or something. How would i go about fixing the code 20 problem
Old Jan 7, 2008 | 09:40 PM
so, instead of checking the normal maintenance items like cap/rotor, ignitor, plugs, plug wires you poured in 108? hehehe
replace the gas and the above mentioned parts and you'll probably be golden.
but i have a feeling your distributor wiring isnt up to the task of running properly for obd-1.
code20 is either bad distributor or bad distributor wiring.
Old Jan 7, 2008 | 09:45 PM
nipcup101's Avatar
i have the rywire adaptor harness i didnt touch the wiring
Old Jan 7, 2008 | 09:47 PM
nipcup101's Avatar
Car was making the noise since it was obd 0. So i didn't think dizzy cuz i know i didn't have 2 bad ones thats why. I tried the 108 it was worth a shot but all i know is it was running fine with 91 and now its not lol.
Old Jan 7, 2008 | 09:52 PM
beats me.... contact rywire to see if they can shed some light on what you did wrong.
Old Jan 7, 2008 | 10:31 PM
Zaakro's Avatar
where in the hell did you get 108? aviation fuel is only 104
Old Jan 7, 2008 | 10:33 PM
Default Re: All crx head come and help car wont rev past 4500 HELP!!!!!!!!!!!!!! (Zaakro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">where in the hell did you get 108? aviation fuel is only 104 </TD></TR></TABLE>
if you're curious.... i can send you link showing where to buy 108-110 octane in so cal.
i assume his 108 is LEADED gasoline too.
EDIT: i guess it's 100-110
Old Jan 7, 2008 | 10:37 PM
Zaakro's Avatar
i assume his 108 is LEADED gasoline too. </TD></TR></TABLE>
umm no thats ok
the highest i have found at a gas station was 93 in San Diego
umm no thats ok
the highest i have found at a gas station was 93 in San Diego</TD></TR></TABLE>
http://harmanmotive.com/raceGas.html
Old Jan 7, 2008 | 11:14 PM
nipcup101's Avatar
there is a vp gas station which has 100 oct at the pump 6.99 a gallon in Ontario CA
djsimm89
Oct 19, 2012 04:29 AM
badassmthr4000
Aug 13, 2007 08:35 PM
CLE
12
Aug 13, 2006 10:38 PM
civiccoupe94
Apr 18, 2005 04:16 AM
