temperature gauge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziaticvang »</TD></TR><TR><TD CLASS="quote">temperature gauge dead need help? </TD></TR></TABLE>'
if you look up vegue in the dictonary this would be there.
did u check to make sure your coolant temp sensor was still there..
Actually do you guys want him to check the ECT sensor, or the temperature sending unit?
The sending unit tells the guage what to read, and it's the one wire plug by the distributor - THAT is the one that he needs to check.
The ECT sensor tells the ECU the temp of the coolant, but doesn't affect the gauge itself. The ECT affects things like idle quality, fuel delevery based on coolant temp, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvmihatch »</TD></TR><TR><TD CLASS="quote">if you look up vegue in the dictonary this would be there.</TD></TR></TABLE>
No it wouldn't, because "vague" is spelled with an "a".
Scrapin4DR
19
Feb 4, 2005 05:32 AM
