axle shake probs m2b4 trans
Old Jan 7, 2008 | 05:35 PM
dartonh22's Avatar
Default axle shake probs m2b4 trans
i have a 93 honda prelude h22 w m2b4 lsd trans and i am having serious vibrating problems only when accelerating between 25 and 50 mph agian only when accelerating
i have new axles not rebuilt from advanced and they still shake have replaced them 3 times but no change
replaced upper and lower ball joints and still shakes
any help is greatly appreciated
Old Jan 8, 2008 | 02:34 PM
Apex1972's Avatar
Default Re: axle shake probs m2b4 trans (dartonh22)
soundslike the LSD is shot to hell
Old Jan 8, 2008 | 06:31 PM
dartonh22's Avatar
Default Re: axle shake probs m2b4 trans (Apex1972)
do you know any way to tell for sure, besides taking it apart
Old Jan 8, 2008 | 06:46 PM
machine4321's Avatar
check out your inner cv joints
my car would rattle really bad , but it also could be the LSD . but axels are easier to check out .
Old Jan 9, 2008 | 04:39 AM
92hondalude's Avatar
Default Re: (machine4321)
well when did this start to happen?
My car just doesnt work with advance axles, i had a simalar problem. I went with car quest axles and never had a problem. Now i have DSS axle 2.9 and we have been trying to find the correct length for my car for a while now.
Old Jan 9, 2008 | 08:29 AM
dartonh22's Avatar
Default Re: (92hondalude)
im fairly sure it's not the inner cv since i have replaced them 3 consecutive times
im not sure exactly when it happened but i think it started after i installed the innovative mounts
Old Jan 9, 2008 | 08:30 AM
dartonh22's Avatar
Default Re: (dartonh22)
92hondalude what lengths have you tried and what is your setup
i just ordered a shorter axle for the right side hopeing it would compensate for the larger m2b4 trans abd possible shift from the innovative mounts
Old Jan 9, 2008 | 09:04 AM
not sure i just have to take the axle nut off and then put the tire back on and lowwer the car back on the ground. Then measure how much the axle is sticking out of the hub. Then lightly tap the axle in untill it stops and measure that then find the difference. I give the difference to DSS and they try a new length. Its hard to measure a axle because it has some play in the joints.
DSS and other performance axles have less play in them, thats one of the reasons why they are stronger.
So like i said before i had the same problem getting axles from advance auto parts with my M2A4 tranny with quaife LSD. try a different brand like car quest. Any place will work just try to get a lifetime warrenty.
Old Jan 9, 2008 | 09:53 AM
dartonh22's Avatar
yeah i have done the same for measureing and have ordered a axle 1/2 inch shorter from dss
my old axle only stuck out 1/2 inch when pushed in all the way so the new one should have a full inch of play
what is yours currently at
Old Jan 9, 2008 | 12:00 PM
im not sure to long ago that i measured it, but its about time to get a shorter size again....
Old Jan 9, 2008 | 12:48 PM
dartonh22's Avatar
why did you get the axle shorter,
was the car shakeing,
and did it fix the problem
why do you need another shorter one
Old Jan 9, 2008 | 12:56 PM
1.i got it shorter because the car was shaking.
2.Yes
3.i keep getting less and less vibrations each time they send it back to me.
4.because i keep sending it back an they just keep taking little bits off at a time till we find the correct length.
Old Jan 9, 2008 | 01:41 PM
Apex1972's Avatar
yeah I had a 92 Accord with H22A4 swap and DSS could never seem to get my axles righ teither. I now have A1 Cardone rebuilts in my 92 Si with H22. They are very good, no vibration at all.
Old Jan 10, 2008 | 07:16 AM
dartonh22's Avatar
Default Re: 92lude
he lude thanks for your info, just wanted to know if you have aftermarket mounts and if so what brand are they. I am wondering if the problem is with the mounts.
Old Jan 10, 2008 | 07:53 AM
Default Re: 92lude (dartonh22)
i have had these axles with energy inserts, and now i have inovative mounts with the grey polly. same problem.
I might add that the mounts are great
Old Jan 10, 2008 | 09:10 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 &raquo;</TD></TR><TR><TD CLASS="quote">soundslike the LSD is shot to hell</TD></TR></TABLE>
What brought you to that conclusion?
Don't use advance auto axles. Raxles makes good stuff.
Old Jan 10, 2008 | 09:17 AM
dartonh22's Avatar
Default Re: 92lude (92hondalude)
so you dont think the mounts caused the need for a shorter axle do you know what did cause the need for this shorter axle
is you car lowered. alot
Gonzo_SiR
52
Mar 24, 2021 11:39 AM
AllShowNoGo727
Nov 14, 2012 01:52 PM
AFAccord
Transmission & Drivetrain
Jan 29, 2009 04:27 PM
WhiteHB15LSD
Apr 1, 2006 02:55 PM
mingchi96
Feb 3, 2002 08:31 PM
