Front End Electrical Problems
Old Jan 7, 2008 | 03:31 PM
95vtecscrapper's Avatar
Default Front End Electrical Problems
Okay, headlights work, corner lights work, but driver's side main t/s bulb won't fire. I've re-spliced the connections, still nothing. Is there a known problem with wire rot or sevvering? I'm new to Acuras after spending years on american muscle. I also keep losing fuses on my interior and dash lights. Is this another common deal? I kind of figured that the audio wires are grounding where they ripped the old system out.. its an auction vehicle. I may be posting here a lot. Thanks for your help in advance!
Old Jan 7, 2008 | 06:02 PM
ls19integra95's Avatar
Default Re: Front End Electrical Problems (95vtecscrapper)
for the interior lights fuses i would check all the wiring behind the radio, probably one bare some where or freyed... as for the turn signal, i had the same problem and it was the socket itself was bad and i had to cut one off a teg in the junk yard and re solder it onto mine inplace of the old crappy one... problem was then fixed and turn signals worked fine then...
Old Jan 7, 2008 | 07:28 PM
NH538DB8's Avatar
You check your turn signal bulb? Does the indicator blink very rapidly when the t/s is supposed to be blinking?
Liberty.R
Lighting
Jan 1, 2013 11:49 AM
Draiga1988
Jan 4, 2012 03:33 PM
JDMDALOUIE
Mar 1, 2010 11:06 PM
tenjintuned
Dec 12, 2007 12:50 AM
hurican
Jul 17, 2004 08:45 AM
