Front End Electrical Problems
Okay, headlights work, corner lights work, but driver's side main t/s bulb won't fire. I've re-spliced the connections, still nothing. Is there a known problem with wire rot or sevvering? I'm new to Acuras after spending years on american muscle. I also keep losing fuses on my interior and dash lights. Is this another common deal? I kind of figured that the audio wires are grounding where they ripped the old system out.. its an auction vehicle. I may be posting here a lot. Thanks for your help in advance!
for the interior lights fuses i would check all the wiring behind the radio, probably one bare some where or freyed... as for the turn signal, i had the same problem and it was the socket itself was bad and i had to cut one off a teg in the junk yard and re solder it onto mine inplace of the old crappy one... problem was then fixed and turn signals worked fine then...
JDMDALOUIE
Mar 1, 2010 11:06 PM
