help installing oil pressure gauge??
Old Jan 7, 2008 | 02:14 PM
lancerkid06's Avatar
Default help installing oil pressure gauge??
i was wondering if anyone has a walk through for installing a oil pressuregauge on a 1990 civic hatch ... or if you had any pictures of where the oil pressure sender unit is .. iknow its above the oil filter somewhere but im not sure .. any help would be appreciated .. thanks
i have a mechanical autometer gauge .. its a cheap one from like advanced .. but then i also have a electrical one my friend gave me but dont have any clue how to hook it up ... so which would be better and easier ....
the electrical has a ground, power, sensor wire, and either a illumination or battery .. dont remember
Old Jan 7, 2008 | 02:18 PM
90EFHatchback's Avatar
Default Re: help installing oil pressure gauge?? (lancerkid06)
uh....there are two plugs right above the oil filter....its one of theso....i cant remember exactly which one....
Old Jan 7, 2008 | 07:17 PM
Crx Jimmy's Avatar
its above the oil filter, you need a 1/8bsp- 1/8 npt adapter for the block , around a 12" piece of braided 1/8npt hose to go from the block to a 1/8npt T fitting. screw the stock sender into the T and run a braided hose from the T to the gauge. Use honda bond on the threaded fittings, dont use teflon. Use a zip tie to attach the T to the firewall
nicko360
Mar 14, 2007 02:52 PM
cjmitthun
75
Nov 21, 2006 08:35 PM
standbackimapro
Apr 30, 2006 07:22 PM
Nov 13, 2004 08:56 AM
RICEBURNER1406
May 8, 2002 08:09 PM
