need help w/ pedal or throttle cable... thanx ht
well everything is fine when i turn the car on.... ok.. so its at 1300 rpm .. i rev it over 4 and let go of the gas and the rev goes down until it hit 2000 rpm//and its stays at 2000/ i have to kinda pull on the gass pedal to make it go back to 1300rpm. pull on it not push....how can i fix this problem.. i knoe its a stupid problem but i cant seen to uderstand whats wrong.. i appreciate the help.....
check the cable for wear. most likely at the throttle body. somethings obviously sticking somewhere if you can pull the pedal back and it stops. does the car have cruise control?
good ideas from everyone.
I would do that maybe clean out your tb as well with some cleaner. Check if the TB cable is over tighten on the Intake Manifold bracket.
good luck!
might be a good idea to replace it, if it hasen't been done..
good luck!
Hey i have the same problem, why did u sak if he had cruise control, i have cruise control and i also have to pull the gas pedal for it to idle normal sometimes. I cleaned the butterfly so i dont think that could be it, i adjusted the cable and i dont see any wear, could the spring need to be tightened so that it can return all the way back? thanks
Mr Synister
Jul 17, 2009 05:37 PM
will try all that tomorrow...... thanx again
