idol problems
Old Jan 6, 2008 | 07:33 PM
newbietuner_si's Avatar
Default idol problems
i have a 96 ex d16y8 and it seems like wen i come to a stop it will fluctuate between 1200 ans 2000 rpms, the only thig that i can think of is mass air sensor. could be because i dont have a vacum hose? any help thanx
Old Jan 6, 2008 | 07:43 PM
ek-g6's Avatar
Default Re: idol problems (newbietuner_si)
have you check you IACV? try cleaning it if it hasent been cleaned.
Old Jan 6, 2008 | 09:19 PM
ferio252's Avatar
if your current IDOL doesn't work, try this one.
Old Jan 6, 2008 | 09:32 PM
MilanoCivic97's Avatar
Default Re: idol problems (ferio252)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek-g6 &raquo;</TD></TR><TR><TD CLASS="quote">have you check you IACV? try cleaning it if it hasent been cleaned. </TD></TR></TABLE>
definately try to clean it first, i had to replace mine to fix the problem though.
Old Jan 6, 2008 | 11:06 PM
FastLife617's Avatar
Default Re: idol problems (MilanoCivic97)
and if u want i can be your idol
Old Jan 7, 2008 | 12:07 AM
leoaa777's Avatar
Oh noooeess!!! My idol is brokenzz!
Your idle could be fluctuating due to the IACV. Remove, clean, re-install.
Also, how do you know its your MAP sensor. Are you getting a CEL? What code?
ARR
Old Jan 7, 2008 | 12:28 AM
ek-g6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio252 &raquo;</TD></TR><TR><TD CLASS="quote">
if your current IDOL doesn't work, try this one. </TD></TR></TABLE>
lols when you have dyslexic fingers you get burned on h-t
Old Jan 7, 2008 | 08:54 AM
Scottyk6's Avatar
I sort of have the same issue. Definitely check/clean the IACV and FITV. There are a few good write-ups online. I have to clean mine and see if it's the problem.
Here's a good reference site...
http://www.ef-honda.com/ben/Badidle.php
Old Jan 7, 2008 | 12:22 PM
Default Re: idol problems (Scottyk6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scottyk6 &raquo;</TD></TR><TR><TD CLASS="quote">I sort of have the same issue. Definitely check/clean the IACV and FITV. There are a few good write-ups online. I have to clean mine and see if it's the problem.
the y8 dosen't have a FITV so dont worry about that. thats a good site for troubleshooting idle problems though...
Old Jan 7, 2008 | 01:27 PM
Funanin's Avatar
sounds like a vacuum hose is leaking or came off. if you can get a hold of a vac guage and hook that up it will tell u whats goin on. Sometimes in the older accords I have seen the brake booster leak and it causes a major idle problem because it kills the vacuum and the cant idle properly. The vacuum at idle should be like 15 inches of mercury if your car is stock and doesnt have any cams or big time engine work.
Old Jan 7, 2008 | 06:26 PM
DseriezDemon's Avatar
Default Re: (Funanin)
agreed, check the vacuum, hook up the gauge to the mani or hell if you can get you hand on one a smoke machine will help with finding a vacuum leak real quick, and also try the iacv.
tylertocker
Sep 21, 2007 11:07 PM
bbbobbb
Honda Motorcycles
Aug 17, 2007 03:48 PM
Jay J
Jun 23, 2005 02:00 PM
moleodonuts
20
Jun 26, 2004 07:49 AM
kysard
Mar 20, 2004 03:17 PM
