built b16a not running like it should
Old Jan 6, 2008 | 04:21 PM
gearhead16's Avatar
Default built b16a not running like it should
i built this b16a completely from top to bottom and its fast but doesnt seem to be right i think it might need a good tune im runinng a b16b computer it feels like it has nothing much untill 7500 and it pulls strong to 9000 i was think of converting to obd1 and getting it tuned what else could be my problem? i think part of my problem was the tranny gears felt real long it was a 96 gsr and i just put a 4.92 final drive and jdm itr jsd in it it revs faster and pulls harder but still doesnt seem right.
was gona get it tuned for nitrous kit i just got.
it has no check engine light plugs look good doesnt seem to be running too lean or rich.
heres what in it.
wiseco forged 11.5:1 pistons
eagle h beam rods
acl bearings
head studs
crower stage 2 3/4 race cams
crower dual valve springs and retainers
blox intake manifold
short ram intake
jvt 4-1 header
apexi ws2 turbo catback
Old Jan 6, 2008 | 04:48 PM
instrument's Avatar
so you built a motor and you're just driving it around on a stock ecu?
Old Jan 6, 2008 | 04:51 PM
gearhead16's Avatar
Default Re: (instrument)
yea pretty much i wanted to keep it obd2 for my emissions witch i passed so now thats why i want to convert to obd1 and get it tuned
Old Jan 6, 2008 | 04:54 PM
gearhead16's Avatar
Default Re: (gearhead16)
i wanted to keep it obd2 for emissions so i got the b16b computer thinking it would run better because of the map in it is closer specs to my engine than the b16a computer so i want to convert and get it tuned so it will run like it should hopefully.
Old Jan 6, 2008 | 05:01 PM
schardbody's Avatar
you have a high compression cammed b16a what exactly do you want it to run like??? i mean 175whp and 115wtq isnt going to make it feel like a rocket.
and those numbers are generous
Old Jan 6, 2008 | 05:04 PM
gearhead16's Avatar
Default Re: (schardbody)
my friend has a b16a in a 97 ex coupe and it pulls just as hard and all he has is type r pistons and a tune thats why i think i should pull better
Old Jan 6, 2008 | 06:11 PM
JKov240's Avatar
Your friend's car is tuned...yours isn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">you have a high compression cammed b16a what exactly do you want it to run like??? i mean 175whp and 115wtq isnt going to make it feel like a rocket.
Old Jan 6, 2008 | 06:38 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearhead16 &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a b16a in a 97 ex coupe and it pulls just as hard and all he has is type r pistons and a tune thats why i think i should pull better </TD></TR></TABLE>
what do you drive???
also, tune, especially with aftermarket cams and HIGH compression is a MUST. your a/f is probably all over the place.
Old Jan 6, 2008 | 06:42 PM
curtisb16's Avatar
Default Re: built b16a not running like it should (gearhead16)
tell you what you need to find a program for youre application and get youre ecu chipped. it will fix youre lack of power the fuel maps need to be boosting moore fuel and fixing peak power points.
99siRACER
Apr 14, 2011 10:03 AM
gearhead16
Sep 9, 2009 09:01 PM
pkripper94
Apr 22, 2004 06:58 AM
9200RPM
May 3, 2003 09:59 AM
