Please read...88 Si B16 wont start...... Need help.
Old Jan 6, 2008 | 02:46 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Please read...88 Si B16 wont start...... FIXED!!!.
Ok, I just did a B16 swap in a 88 CRX Si. I went to start it after the swap, and it just turns over. I double checked the timming belt and its fine...
I checked the fuel pump wires with the key on with a test light because I dont have a voltmeter, and theres no power. I checked the fuses and all seem to be good. So I replaced the main relay and still no power at the fuel pump wires with the test light. I also replaced the fuel filter, and after trying to start it, its still empy. So its not getting fuel.
It has a full tank of gas, and before I replace the fuel pump I want to make sure im not missing anything else. The engine ran perfect a month ago when I pulled it from my old crx.
What else should I look for under the dash for the fuel pump? Any help would be great.... Thanks Alex
Modified by Dc4iNtEgRa at 7:02 PM 1/6/2008
Old Jan 6, 2008 | 03:04 PM
krops13's Avatar
Default Re: Please read...88 Si B16 wont start...... Need help. (Dc4iNtEgRa)
if your fuel pump was working then what
would make it go bad. did you check to
see if it has spark?
Old Jan 6, 2008 | 03:11 PM
Dc4iNtEgRa's Avatar
Default Re: Please read...88 Si B16 wont start...... Need help. (krops13)
Its got spark... The fuel filter is empty... Theres no power at the three wires under the storage compartment in the back... Main relay is brand new...
Fuel isn't getting to the engine. Before I replace the fuel pump, Im wondering why there is no power at the plug for the fuel pump by the sending unit.
Old Jan 6, 2008 | 04:22 PM
Dc4iNtEgRa's Avatar
Anyone???
Old Jan 6, 2008 | 04:59 PM
Dc4iNtEgRa's Avatar
The main relay doesn't even click??? Its got power to the wires going to it.
Which wires should have power going to the relay??? Some are weaker than others with my test light... PLEASE HELP...
Old Jan 6, 2008 | 06:01 PM
Dc4iNtEgRa's Avatar
Fixed!!!!!!! Im not afraid to admit it, but when I installed the harness on the engine, I forgot to put the ground on the thermostat housing. I hooked it up, relay clicked, fuel pump cycled, and she fired up! Big weight off my shoulders! Now gotta finish the rest and convert it to obd-1.
Old Jan 6, 2008 | 06:17 PM
tegman23's Avatar
i just read this tread and was about to tell you to check your ground same thing happened to me before damn grounds haha
Old Jan 6, 2008 | 08:29 PM
Dc4iNtEgRa's Avatar
Default Re: Please read...88 Si B16 wont start...... Need help. (tegman23)
Yup... Im glad I looked up the service manual on the net... Too many beers and working on a car by your self= mistakes... LOL
Mref813
11
Dec 12, 2009 01:35 PM
jstafase
Jun 15, 2009 09:15 PM
solvent5
May 7, 2008 07:21 PM
billy_thekid
Jan 5, 2008 06:04 AM
curioso
Sep 19, 2007 05:06 PM
