DaMN This motor...please help
Old Jan 6, 2008 | 11:55 AM
h23vtak's Avatar
Default DaMN This motor...please help
Ok so i decided to change my head gasket... motor starts coming apart just fine until the 2 head bolts on each side of the head wont break loose... i tried several different patterns and i cant break these bolts loose. They are flexing like they are going to break and i dont want that to happen. So then i decided to put the head back together and just sell the car as is... well now the timing belt tensioner wont budge.... we took the bolt completely out of it and it shouldve just dropped off but its stuck on there.... its an h23 btw.... what would you guys recommend me doing?
Old Jan 6, 2008 | 11:59 AM
95greenlude's Avatar
Default Re: DaMN This motor...please help (h23vtak)
getting a longer breaker bar and an impact grade socket
Old Jan 6, 2008 | 12:10 PM
h23vtak's Avatar
Default Re: DaMN This motor...please help (95greenlude)
tried a impact and it wouldnt touch it and then tried a Snap-on breaker bar with a 10 foot pole on the end.... that bolt wont budge... its gonna snap if i force it... doesnt it ruin the block if it snaps inside the thread?
Old Jan 6, 2008 | 02:09 PM
cb7tougeracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtak &raquo;</TD></TR><TR><TD CLASS="quote">tried a impact and it wouldnt touch it and then tried a Snap-on breaker bar with a 10 foot pole on the end.... that bolt wont budge... its gonna snap if i force it... doesnt it ruin the block if it snaps inside the thread?</TD></TR></TABLE>
dang if those couldnt get it loose try wd40 then brake it loose
Old Jan 6, 2008 | 02:19 PM
h23vtak's Avatar
Default Re: DaMN This motor...please help (cb7tougeracer)
yea im about to trash the damn motor and frab an h22 block to go with the head in my room and drop that in.
Old Jan 6, 2008 | 02:25 PM
mattsnooz's Avatar
Could you maybe heat the nut/bolt with a torch. Just buy the once piece torch with the tank on it (blue ones)
If you can though try some penetrant. Spray soak the nut/bolts with good penetrant (not wd40, theres way better stuff on the market now)
Heating would be LAST resort though in your case.
Exhaust work, heating bolts is almost a must when nuts/bolts are siezed solid.
vinuneuro's Avatar
Use a long breaker bar, and then use a longer pipe on that. There's no reason you shouldn't be able to take the head bolt out.
Old Jan 6, 2008 | 04:37 PM
h23vtak's Avatar
Default Re: DaMN This motor...please help (vinuneuro)
lol read my original post... i had a 6' pole on the end of the breaker bar
Old Jan 6, 2008 | 04:49 PM
vinuneuro's Avatar
Did you remove them in the right order?
Old Jan 6, 2008 | 06:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Did you remove them in the right order?</TD></TR></TABLE>
didnt think of that but that does matter
Old Jan 7, 2008 | 07:13 AM
bluedlude's Avatar
yeah, you have to torque sequence. they didnt make that up for no reason. a 6' pole should work pretty easily
Old Jan 7, 2008 | 08:15 AM
h23vtak's Avatar
Default Re: DaMN This motor...please help (bluedlude)
yes ive tried the torque sequence... i guess im looking for a h22 block now... lol i have a fully built head in my room but i guess i might as well build a block and drop it in
Old Jan 7, 2008 | 08:24 AM
Hawkze_2.3's Avatar
So the head bolts are still in there? I would say soak them in WD40 or PB Blaster or whatever you like overnight and just go for it. If they break they break, but there's a good chance you will get them loose also.
Old Jan 7, 2008 | 09:46 AM
h23vtak's Avatar
Default Re: DaMN This motor...please help (Hawkze_2.3)
yea the car is being trailered back to my place tonight so ill soak it with that PB penetrating catalyst. Yea if they break in the block whats that mean... Replace the block or is it possible to drill it out?
Old Jan 7, 2008 | 10:05 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtak &raquo;</TD></TR><TR><TD CLASS="quote">yea the car is being trailered back to my place tonight so ill soak it with that PB penetrating catalyst. Yea if they break in the block whats that mean... Replace the block or is it possible to drill it out?</TD></TR></TABLE>
Yeah, any good machine shop should be able to get those broken bolts out for sure. I wouldn't give up on it just for that.
You could try to remove them yourself with those bolt extractor kits, but I would think that would just be a major headache...
Old Jan 7, 2008 | 02:42 PM
h23vtak's Avatar
lol, if they break then ill take it to a machine shop. Hell, if I take it to a machine shop I might as well go ahead and resleeve the block for forged pistons...
Old Jan 7, 2008 | 03:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtak &raquo;</TD></TR><TR><TD CLASS="quote">lol, if they break then ill take it to a machine shop. Hell, if I take it to a machine shop I might as well go ahead and resleeve the block for forged pistons...</TD></TR></TABLE>
Old Jan 8, 2008 | 03:31 AM
PirateMcFred's Avatar
If you really think that the bolt's going to twist off then drill the bolt's head. If you just crank on it and it twists off you don't get to choose where. It could be down in the block by the threads or in the middle of the shank. Who knows. You could have a very tricky issue on your hands depending on where it break.
If you drill it it will pop the bolt head off and you can then pull the head. The benefit of drilling as a last resort is that there will be about 6" of bolt sticking out of the block afterward that you can get a hold of to remove after the head.
Old Jan 8, 2008 | 07:12 AM
h23vtak's Avatar
Default Re: DaMN This motor...please help (PirateMcFred)
yea thats been considered and most likely thats what im going to do... just to play it safe
Old Jan 8, 2008 | 08:09 PM
h23vtak's Avatar
can you drill iron bolts?
Old Jan 9, 2008 | 12:47 PM
bluedlude's Avatar
get a good carbide bit.
Old Jan 9, 2008 | 07:27 PM
You're not going to find any inexpensive carbide drills. Endmills and countersinks yes, but not drills. A standard drill should be enough. But you should get a center drill too to keep the larger drill from walking.
Pirate
Zinch
Mar 17, 2007 06:26 PM
JokerTypeR
Feb 7, 2007 08:39 AM
mixmastermatt
Feb 1, 2007 12:03 PM
2civic3
May 22, 2006 06:13 PM
wm5holla
Feb 21, 2003 03:34 AM
