Best way to shave side moldings??
Old Jan 6, 2008 | 11:52 AM
integranator's Avatar
Default Best way to shave side moldings??
Just like it says, what do you guys think the best way to shave our side moldings? Weld plates from the inside and bondo on the outside? Need help!
Old Jan 6, 2008 | 12:05 PM
clean3two3's Avatar
Default Re: Best way to shave side moldings?? (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">Just like it says, what do you guys think the best way to shave our side moldings? Weld plates from the inside and bondo on the outside? Need help!</TD></TR></TABLE>
x2
Old Jan 6, 2008 | 07:02 PM
BOTAN01's Avatar
thats what i did with mine. i bought some tin and cut little square pieces and welded them on from the inside. after that i used bondo from the outside
Old Jan 10, 2008 | 07:04 AM
Default Re: (BOTAN01)
is there any type of metal that would work best? Or just tin?
Old Jan 10, 2008 | 10:13 AM
wing.jai's Avatar
do both
Old Jan 10, 2008 | 02:11 PM
ImportHatch's Avatar
Default Re: (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">is there any type of metal that would work best? Or just tin?</TD></TR></TABLE>
Tin?
Old Jan 10, 2008 | 03:13 PM
melovesboost's Avatar
why not ask the paint and body forum?
Old Jan 10, 2008 | 06:29 PM
Dann6968's Avatar
Default Re: (melovesboost)
Gillette Mach 3
Old Jan 10, 2008 | 07:29 PM
Default Re: (Dann6968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dann6968 &raquo;</TD></TR><TR><TD CLASS="quote">Gillette Mach 3</TD></TR></TABLE>
haha.
Old Jan 11, 2008 | 04:08 PM
locashcustomz's Avatar
Default Re: (ImportHatch)
Just by a sheet metal or if you have a junk fender cut squares out make sure u grind them to bare metal! then take of the door panel off and use panel adhesive 3m makes it as well as fusor and other brands then attatch the metal over the holes from the inside. Bodyshops use it all the time! No welding involved so less corrosion and i thinks its easier! then grind down the outside of the door fill with a little filler -prime-paint!! GL
Ryan
Old Jan 12, 2008 | 08:43 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
Default Re: (locashcustomz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locashcustomz &raquo;</TD></TR><TR><TD CLASS="quote">Just by a sheet metal or if you have a junk fender cut squares out make sure u grind them to bare metal! then take of the door panel off and use panel adhesive 3m makes it as well as fusor and other brands then attatch the metal over the holes from the inside. Bodyshops use it all the time! No welding involved so less corrosion and i thinks its easier! then grind down the outside of the door fill with a little filler -prime-paint!! GL
Ryan </TD></TR></TABLE>
this is the easiest way without welding plus its durable
Old Jan 12, 2008 | 08:49 PM
Default Re: (2'z kuztoms)
Thanks for the back up on that method!!! Also if you have a dent puller/stud gun use that to attach a stud to hold up the little squares while the panel bond dries otherwise goodluck washing that panel bond off your hands!!
Old Jan 12, 2008 | 09:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locashcustomz &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the back up on that method!!! Also if you have a dent puller/stud gun use that to attach a stud to hold up the little squares while the panel bond dries otherwise goodluck washing that panel bond off your hands!!</TD></TR></TABLE>
and also you can use a magnet
Old Jan 12, 2008 | 10:11 PM
Damn even better idea!!!!
Old Jan 13, 2008 | 03:18 PM
94_integra's Avatar
Magnet I prefer welding it over panel bond. Could be a good idea to spray some zinc weld-thru primer on your small metal tabs as you will have a bit of bare metal overlap once they're welded on.
Old Jan 13, 2008 | 04:18 PM
reactone's Avatar
Default Re: (94_integra)
If you can reach them, I would apply some rust proofing paint such as por-15 on the inside on the welds(inside the door). I shaved some moldings on an eg some time ago, and they began to rust from the inside out.
Old Jan 13, 2008 | 06:48 PM
Default Re: (reactone)
Another reason why i dont weld the ones i fill they just seem to rust so fast but even if you did the panel bond method i would say put some undercoat over the area on the inside!!!!
Old Jan 13, 2008 | 07:34 PM
jvtec95's Avatar
My body guy said that welding them in increases the chances of developing waves in the door, especially on the thin honda metal. He used fusor metal bond and small metal squares for the rear quarter panel.
The best method for the doors? Do what I did, buy ITR doors! You'll probably end out ahead with how many hours will go into shaving them.
2point2
Welding / Fabrication
21
Oct 1, 2012 11:07 PM
jdmbb6-t
Jun 23, 2006 02:44 PM
jjs316
35
Jun 20, 2006 05:47 PM
MadnessRacing
Honda Motorcycles
Sep 26, 2005 11:33 PM
chinoty
Jul 16, 2005 10:34 AM
