H22 Egr an Iacv problem?
Old Jan 6, 2008 | 09:38 AM
H-EK22's Avatar
Default H22 Egr an Iacv problem?
Ok me and my friend both have h22 swaps on our civic but his a lil faster, his has egr blocked off and a couple other stuff, mine dont, whats the benefits on that.......and also i heard of poeple blocking off their Iacv????? i have a 93 jdm H22 engine his is a 96.....thanks
Old Jan 6, 2008 | 11:49 AM
H-EK22's Avatar
Default Re: H22 Egr an Iacv problem? (H-EK22)
yoo who!
Old Jan 6, 2008 | 11:53 AM
Acidcrakker's Avatar
blocking off the egr will not give you any power gains. ALl it does is recycle exhaust gas into the intake at crusing speeds. Nothing to do with full throtal.
As for your friends motor, well its a 96 and yours is a 93. His motor is probally in better condtion than yours and is probally why it performs better.
Old Jan 6, 2008 | 11:54 AM
mattsnooz's Avatar
They are usually attempts to remove poor idles, buy blocking potential vacuum leaks that occur when those* systems fail (egr, iacv,) And also to reduce heat (FITV) at the throttle body/intake to keep the air as cold as possible.
So how do you know his is faster? Do you guys actually swap rides and than You beat him with his car (thus proving its not the driver but actually the car) or by comparing butt dyno numbers?
Old Jan 6, 2008 | 12:11 PM
H-EK22's Avatar
Default Re: H22 Egr an Iacv problem? (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">They are usually attempts to remove poor idles, buy blocking potential vacuum leaks that occur when those* systems fail (egr, iacv,) And also to reduce heat (FITV) at the throttle body/intake to keep the air as cold as possible.
So how do you know his is faster? Do you guys actually swap rides and than You beat him with his car (thus proving its not the driver but actually the car) or by comparing butt dyno numbers?</TD></TR></TABLE> well we've run them like three times an we both have I/H/E same models... an hes has egr an iacv block of plates plus msd, light wheight pulley, an he beats me out by like a car lenght or car an a half what should i get???
civic_std
10
Dec 21, 2005 09:57 AM
Ginker
Jul 11, 2005 12:00 PM
KStuned
Sep 28, 2003 09:51 AM
TylerB
Aug 29, 2003 06:58 PM
SCsol
Dec 22, 2001 10:43 AM
