trunk and drivers side window
Old Jan 6, 2008 | 08:38 AM
dc2go's Avatar
Default trunk and drivers side window
ok its a 98+ the window doesnt open and close...also the trunk doesnt open up either. whats the first thing to check?
Old Jan 6, 2008 | 09:10 AM
shad0wslay3r's Avatar
Default Re: trunk and drivers side window (dc2go)
The trunk doesn't open as in.. Its locked? Or it doesn't stay up? Or what.
If it doesn't stay up you need to struts.
Power Window? First check your fuse. Then check connection to the motor. If that is all ok you need a new motor for the window
Old Jan 6, 2008 | 09:38 AM
dc2go's Avatar
its locked ^^
the window i switched motors and it seems like the motor is fine...ill have to check the wires then. anything else?
Old Jan 6, 2008 | 11:03 AM
Try your key in. I'm not sure if these cars have a seperate key for the hatch/trunk. When I got mine the previous owner shaved the key hole in the trunk and took out the lock. If you hit the hatch release and it still doesn't open it might just be stuck, or the actual release is messed up. Could be the cable
Old Jan 15, 2008 | 03:53 PM
dc2go's Avatar
ok the trunk works now but the window aint working...wire seems fine. anything else? drivers side is ok but passenger isnt working
theazndog
Jun 22, 2009 09:43 AM
theazndog
Jun 12, 2009 12:05 PM
EGKREW
Nov 20, 2008 10:06 AM
TRYLSTEG808
Mar 3, 2008 05:55 PM
illusion
Mar 15, 2002 04:16 PM
