boosting d16y7 need help
right now i have a project to rebuild a d16y7 and boost it witha vtec head...
what would be everything i really need
heres my list..
vitara pistons
eagle rods
better flowing oil pump
new water pump
bigger injectors..dsm 450cc injectors
turbo kit
turbonetic t3/t4 turbo..
questions i have
the eagle rods do work with the d16y7 right?
do i have to build the head too..?
Modified by 99_itr at 1:24 PM 1/6/2008
heres my list..
vitara pistons
eagle rods
new water pump
turbo kit
questions i have
The (d16)y8 intake manifold would help you out a bit if you can get your hands on one. 450CC injectors are plenty for your application. DSM blue/black-tops will work well. I'd also purchase a 255lph hi pressure walbro fuel pump. Proven dyno gains and it will replace your tired old stock pump. Get a stage 2 Exedy clutch or the equivalent (stage 1 is crap for turbo'd civic's), and a resurfaced flywheel. Some people would argue that a lighter flywheel will get your rev's up faster, but a heavier wheel will keep the rev's up for a longer period of time. Resurfacing your stock steel flywheel is cheaper than buying a new name brand one anyways, around $40.
You can easily make reliably make 250WHP-ish no problems, depending on the turbo kit you purchase. I would also upgrade from your stock exhaust and get a (NOT crush-bend) mandrel bend 2.5 inch exhaust from the cat-back. If you don't have emissions standards, you should also get a test pipe, you will notice a bit of difference from the stock cat.
https://honda-tech.com/zeroforum/16
I wonder why nobody posts Forced Induction questions in the Forced Induction Forum....
Because they are a huge pile of fail. Every time I've gone in there all I get is sarcastic, *******-ish answers. Hard to find good people to answer your questions there.
Trim and A/R size? A t3/t4 turbo will have no problems making 250WHP. Mine is rated for 400WHP @ .57 trim, .63 A/R on exhaust housing side.
I daily drove a y7. Non vtec. Stock motor about 100k miles. With a t3 super 60 @ 15 lbs for over a year, Made 238whp. Only reason it let go was the timing belt. You dont really need to build it for a fun DD. Put the turbo setup on, a good clutch. Y8 intake manifold. And an ex trans. And you will love it.
You do not need to build the head for higher-rev's unless you want to make gobs of power. Yes, an ex/si tranny would really help out, the steel shift forks along with the short gearing is pretty nice for acceleration, although not as bad as the b16 for highway driving. You don't need a boost controller unless you want to run higher than stock boost, which would be the external wastegate spring psi rating.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">Because they are a huge pile of fail. Every time I've gone in there all I get is sarcastic, *******-ish answers. Hard to find good people to answer your questions there.</TD></TR></TABLE>
You must be asking the wrong questions or giving the wrong answers....people aren't really that bad in the FI forum. At least many of the FI regulars know what they're talking about which isn't common in any of the other sub-forums (regarding turbo setups)
