Help with ITR swaybar (pics included)
I installed the itr swaybar and rcrew brace this afternoon on my eg and when i installed the endlinks onto the lca, the endlinks arent flush/vertical with the lca. Am i doing something wrong or am i in need of different endlinks? I'm also using megan lca's btw.
those itr endlinks fit lot better than they did on my ek lol. didnt even line up at all. blox adjustable endlinks are the **** though, most vendors on h-t sell em for 40-45shipped
Modified by Andyroo at 9:15 AM 1/6/2008
it should be fine, but u mite end up scratchin up ur lca if the endlink is rubbing on it. get some blox adjustable endlinks, they work great and are only 40ish shipped to ur door. but as long as everything's secure and tight there shouldnt be a problem, try using some washers to space the control arm out from the endlinks
yea, it was already preloaded when i installed. there is a couple mm before the endlinks will rub on the lca but i will definitely look into the adj. endlinks. thanks all for the help.
shermanyang
39
Nov 17, 2002 04:53 PM
S2K2S
Aug 7, 2002 10:49 AM
