new motor idling to high
Old Jan 5, 2008 | 03:56 PM
MotorSpecies ver1.6's Avatar
From: MoonSHINE Metropolis, .FL. Run Free, North America
Default new motor idling to high
hello, i recently just finished a new b16a w/ 11.7c/r and skunk2 stg. 1 cams(running obd0). My problem is the motors idle wont drop past 1700rpms when its at operating temp. I blocked the fitv off with a plate,paper gasket, and honda bond. My lap top displays 19inches of vacuum(BRE).The throttle cable is loose,the throttle stop screw is positioned and the idle adjustment screw is completely screwed in.the dizzy is at full retard and the iacv heats up.its an itr manifold with hondata im gasket and a 64mm tb.Im confused.
Old Jan 5, 2008 | 07:27 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: new motor idling to high (MotorSpecies ver1.6)
Check for vacuum leaks.
Check your target idle in BRE.
Loosen your throttle cable more. From the pic, it looks a bit tight.
Old Jan 6, 2008 | 04:01 PM
dr.garagetuner's Avatar
i notice on the right side of the manifold where u have that white vaccum cap at. its suppost to go to the fuel pressure regulator try that and see how it goes
h-o-n-d-a
Aug 3, 2009 05:15 PM
95dc2teg
Sep 11, 2007 05:49 PM
go2sleep
Jun 27, 2006 01:36 PM
honda06si
Nov 24, 2004 02:35 PM
metal-x
Nov 21, 2002 05:35 AM
