**l OBD2 swap into an OBD1 car...Questions!!!!!!!**l
Old Jan 5, 2008 | 08:39 AM
.PLUMMM's Avatar
Default **l OBD2 swap into an OBD1 car...Questions!!!!!!!**l
Note: I did search but came up with a lot of partial answers. Most of the threads covered before were talking soley about wiring harnesses or conversion harnesses to the other ECU. My question is totally different.
I am planning on buying a 2001 Acura Integra Ls swap in a few weeks. With this being a complete swap (Motor, Tranny, ECU, Wiring harness, Axles, Shift linkage, etc.) at a fair price, it seems to be the perfect upgrade from my single cam. I am hesitant to buy it though because it is an OBD2 swap that I am putting into my OBD1 1994 Civic Dx Sedan. My question is, with the complete swap being put in (wiring harness, ECU, OBD2 alternator and dizzy, etc.), will I need to modify anything because my car is OBD1? Or will everything just fall into place because EVERYTHING else is OBD2.
Thanks for all of HT's help in advance!
Old Jan 5, 2008 | 10:02 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: **l OBD2 swap into an OBD1 car...Questions!!!!!!!**l (.PLUMMM)
first off, use the hearness off of your car or you in for a world of hurt. (only saying that because i am not sure 100% if it will work. and it sux rewiring an engine in the car)
i know somewhere there is a thread for re pinning the alternator.
msd makes a dizzy adapter. you are better suited running an obd1 ls ecu. other than that, you dont need to even hook up the CKF sensor, everything else should be good to go. the evap purge is a little different but can be phenagled to work.
Old Jan 5, 2008 | 11:03 AM
.PLUMMM's Avatar
Yeah, most people are telling me to use my harness and injectors and get an OBDI P75. For the dizzy adapter, I am thinking about going with the on rywire makes (http://rywire.com/store/obd2-bseries...cd27affe300834). I think that is the one I want but im not completely sure. Any one had any product experience with this? Also, I have no clue how to go about rewiring my alternator. Anyone with any experience with this aswell? Thanks for the help guys
Old Jan 6, 2008 | 04:40 AM
.PLUMMM's Avatar
bump
Old Jan 6, 2008 | 02:59 PM
AlwayzSpoolin's Avatar
Default Re: (.PLUMMM)
Just convert everything over to OBD1.. I put a 99 GSR motor into my 92 hatch, and I converted the motor over to OBD1 by changing :
Injectors
Dizzy
Alt.
Engine harness
ECU
I had to get an OBD1 engine harness cuz my hatch came with no motor... So use your injectors and engine harness , get the dizzy adapter and get a OBD1 P75 and you should be good to go.
Old Jan 7, 2008 | 10:41 AM
.PLUMMM's Avatar
I understand everything but the alt. How did you repin it? or which one did you buy?
Old Jan 7, 2008 | 02:42 PM
grtek's Avatar
I'm doing this right now too, but I don't have the obd1 harness in my new car, but my donor car has everything in it. Can I just use the obd2 harness from the donor?
I don't mean to hijack or anything, I've just been searching and I can't seem to find a straight answer. Everyone just keeps saying to covert all the parts to obd1, but that seems like a hassle if I already have everything.
Old Jan 7, 2008 | 02:47 PM
grtek's Avatar
nvm found my anwer just now
http://www.ff-squad.com/techne...2.htm
maybe that will help you too OP
Old Jan 8, 2008 | 12:46 PM
.PLUMMM's Avatar
Thanks man. Def!
Old Jan 9, 2008 | 12:30 AM
Katman's Avatar
I just updated this article in the area I speak about wiring in a 2nd 02 sensor and performing the CKF Fix.
JustAskMe
Aug 19, 2010 10:47 AM
turbo2001gsr
Dec 15, 2008 12:08 PM
white2draccord
Nov 10, 2008 08:15 PM
.PLUMMM
13
Feb 18, 2008 10:39 PM
WangChung
11
Oct 9, 2003 07:11 PM
