car wont stay in 4th gear
Old Jan 4, 2008 | 09:35 PM
knight_kidD's Avatar
Default car wont stay in 4th gear
so i was driving to work normally and the transmission started to act up, it wouldnt stay in to 4th gear but all of the other gears seem to be perfect. by the way it's a b16 tranny. anyone have any idea what can cause this??
Old Jan 4, 2008 | 09:46 PM
InTeNsE805vp's Avatar
Default Re: car wont stay in 4th gear (knight_kidD)
sounds like a bad synchro. I think you can have it repaired but I just bought a new tranny when it happened to me.
Old Jan 4, 2008 | 11:47 PM
v8ftl's Avatar
I'm a Jackass
its the shifter bushing. try that first its cheaper than a new synchro
Old Jan 5, 2008 | 01:04 AM
Turbo-GSR1287's Avatar
Default Re: car wont stay in 4th gear (v8ftl)
If there is too much play in your shifter i would say bushing, But if there really isn't much play in the shifter most likely a bad Syncro. I have seen Bushings SHOT to **** and still not throw the car out of gear.
Old Jan 5, 2008 | 06:46 PM
Default Re: car wont stay in 4th gear (Turbo-GSR1287)
thanks a lot for the info. a shop said he could build it for 300 is that a good price??
Old Jan 5, 2008 | 07:00 PM
igotvtec16's Avatar
v8ftl where you from??? i call my hometown gtown too...
if its throwing you out of gear then i dont think itd be the syncro,idk what itd be
Old Jan 5, 2008 | 10:45 PM
egb18c5's Avatar
Default Re: (igotvtec16)
most likely its the teeth on the gears that connect to the synchro, if its rounded, then that means its not locking on
sii.
Sep 4, 2009 10:15 AM
si_ek
May 22, 2008 07:43 AM
DHoff 024
Jun 12, 2006 02:29 PM
Inextricabledrvr
Apr 13, 2005 10:02 AM
