Transmission Question???
Old Jan 4, 2008 | 07:15 PM
d_EG COUPE's Avatar
Default Transmission Question???
Okay i dont if my tranny is blown but its my fourth gear... I mean i can put it in gear but once i release the clutch it juss grinds and pops. but i mean i can put in gear so i dont know... Could it be that theres no fluid or is the gear juss gone. Can some1 tell me wats wrong... Thanx
Old Jan 4, 2008 | 08:13 PM
PuroMotor's Avatar
Maybe the shifter fork?? no way to know unless you get dirty and drop the tranny.
Old Jan 4, 2008 | 08:16 PM
d_EG COUPE's Avatar
would i have to take it apart???
Old Jan 4, 2008 | 08:20 PM
PuroMotor's Avatar
well if you have checked that that fluids are good and nothing else seems to be helping. I guess your only option is to drop it and take it apart to see if there is a broken piece. The problem you described was exactly what a buddy of mine had and it turned out to be a broken shifter fork.
Old Jan 4, 2008 | 08:45 PM
d_EG COUPE's Avatar
shifter fork??? dont knoe wat that is but ok. is it expensive??? i dont even have the dip stick for the tranny fluid and how and where would i put the tranny fluid in???
Old Jan 4, 2008 | 09:21 PM
PuroMotor's Avatar
shifter fork moves the gear into place... as for the fluid there are two bolts in the tranny one of them you can put fluid into.. too bad i dont have any pics to show you exactly what you need. but ill try to go and get some snaps for ya....
Old Jan 4, 2008 | 09:25 PM
PuroMotor's Avatar
Ok i got a pic. its not the best of them but hopefully u get an idea as to where to look.
You want to drain the tranny. and refill it with the proper fluid. hopefully that solves the problem so that you wont have to take the tranny apart.
Old Jan 4, 2008 | 09:26 PM
d_EG COUPE's Avatar
thanx cuz ima noob to tranny's so i dont wats up wit trannies. THANX
Old Jan 4, 2008 | 09:27 PM
PuroMotor's Avatar
Happy to help. good luck!!
mario_pic's Avatar
Default Re: Transmission Question??? (d_EG COUPE)
if its a 92-95 chances are its a shift fork there weak if u do a lot of hard down shifting if its busted just get a 96 there stronger
Old Jan 4, 2008 | 09:33 PM
d_EG COUPE's Avatar
i dont knoe much bout trannies but i have a 91 ls in my ef... will a 96 or nwer fit??? usually i use same year motor/tranny
Old Jan 5, 2008 | 06:10 AM
eda6's Avatar
Default Re: (d_EG COUPE)
I recently bought a used y1 tranny. shifting from 3rd to 5th because 4th grinded no matter what really bothered me, so i dropped the tranny and opened up the case. found zero clearance between 4th gear and the synchro ring. the teeth on the gear and synchro sleeve are fubared. disassembled the mainshaft and scuffed up the gear cones on 3rd 4th and 5th with 120 grit sandpaper . installed a used 5th gear synchro ring from a usdm a1 on my 4th gear and clearance was restored. reinstalled the tranny and filled it with mobil 10-30 non synthetic. took third gear up to 6k last night and shifted into 4th flawlessly.
check the tranny faqs in the tech forum. d/l a 90-93 integra helms manual. open up your tranny and figure out what's wrong.
you'll need to purcahse 90-91 integra replacement parts for your tranny. good luck
Old Jan 5, 2008 | 10:17 AM
d_EG COUPE's Avatar
man i didnt understand any of that ... hahahahha oh well thanx i look into it.
Thanx for all the help guys
miamiboy91
Apr 16, 2009 04:26 AM
polishedturd
Nov 29, 2007 05:59 AM
B-B-K
Oct 5, 2004 03:32 PM
IEATLINT
Sep 10, 2004 12:52 PM
markv
Oct 25, 2003 03:40 PM
