Fuel Issue
Old Jan 4, 2008 | 05:20 PM
B18c1vicrx's Avatar
Default NEED HELP ASAP!!!
coming home today, my fuel was low and the car began to sputter and idle really low, around 400 and when i gave it gas it wouldn't raise rpm. so i pull over and get some gas and put it in the car so i know i have gas but nothing changes, it turns on but idles low and when i give it fuel it still sputters, and may rise to 500 but nothing more, rpm won't go high enough to drive...what could it be??? perhaps a fuel pump?
Old Jan 4, 2008 | 10:23 PM
IP RACING's Avatar
Default Re: NEED HELP ASAP!!! (B18c1vicrx)
sounds like a faulty fuel pump man
Old Jan 4, 2008 | 10:39 PM
x4thGenCafe's Avatar
OF THE KINGS
check the spark plugs and spark plug wires maybe . .
oh and does it feeel like it Doesnt wanna drive at all , like super sluggish ?
Old Jan 5, 2008 | 01:38 AM
424racer's Avatar
yeah check your fuel pump (fuel presser)
and check your spark plugs (gaping)
i had the same problem but it was my dizzy.
i gave it gas and it wanted to die out even more.
same with the map and tps sensors.
Old Jan 5, 2008 | 07:41 AM
B18c1vicrx's Avatar
yeah sluggish is a good word, like im pushing it but it refuses to take it...no homo...and also i tried starting it up just now for the first time since the car cooled down and now it just refuses to start...does this further justify a fuel pump? i know my spark plugs are probably pretty bad since the car runs very lean, the tips of them are white as a ghost but there isn't even more then about 2000 miles on them
Modified by B18c1vicrx at 5:33 PM 1/5/2008
Old Jan 5, 2008 | 09:20 PM
B18c1vicrx's Avatar
and would a fuel pump give out as im driving the car?
Old Jan 6, 2008 | 07:18 PM
B18c1vicrx's Avatar
well today i pulled the return line coming from the egr valve and is shot a little big of gas out, followed by nothing...fuel pump for sure?
Old Jan 7, 2008 | 09:17 AM
alscrx's Avatar
Default Re: (B18c1vicrx)
Check your main relay
Is the pump cycling?
Old Jan 7, 2008 | 07:05 PM
B18c1vicrx's Avatar
i dont think so since there is no fuel shooting out of the return line
Efluis
Jun 27, 2019 09:42 AM
JDMhondalude22
Nov 1, 2006 08:10 AM
patrick4588
May 26, 2006 03:14 PM
trooper0641
Jul 24, 2005 11:11 PM
ABTDer
Oct 30, 2003 06:30 PM
