Is a Skunk2 ecu realible on OBD2?
Setting up for N/A, just wondering if this will work well,or a whole OBD1 conversion with Skunk2 Ecu is better?....i heard about the Hondata as well?, if so which stage is better also would it be required to switch to OBD1 as well..or OBD2 should work the same with Hondata....
**NOTE: doing an all motor set-up
Sorry if this topic has been posted before..just need a little info...**Search didnt help***
I have never understood why people are buying an aftermarket ECU when you can buy a fully standalone for the same ammoutn of money. You can reprogram it always when you make changes to your engine-setup.
Go Hondata when you have access to a knowledge Hondata pro and a dyno.
The best standalone is worth nothing, when the user sux.
go with 2b on hondata but you need to have a guy that can burn the program and socket your ecu for that.
if i get the obd1 with skunk 2ecu would that be a stand alone system...or should i combine that with the hondata stage 2....??
am i looking alot of $$
either way you have to convert to obd1 you can't combine them both. hondata is a completely custom program based around your engine's parameters
