Valves hitting pistons
Old Jan 4, 2008 | 04:53 PM
gs1gsr's Avatar
Default Valves hitting pistons
.Ok so I have an LS-V with GSR head/cams that I got and took it apart because was not sure of the condition of the motor. When the head came off I can see were the Intake valves were hitting the pistons. There is a perfect grove on all the pistons. The valves look fine as far as I can tell. It had the stock head gasket also. My question is why are the valves are hitting the pistons. I thought there should be more clearance.
Old Jan 4, 2008 | 05:00 PM
ekb16's Avatar
are you talkin about the valve relief on top of the pistons?
Old Jan 4, 2008 | 05:24 PM
Mikey3000's Avatar
Default Re: (ekb16)
lol i think he is. sorry i couldn't help but laugh.
Old Jan 5, 2008 | 09:22 AM
gs1gsr's Avatar
Default Re: (Mikey3000)
Yea looking at the top of the piston there are groves for the valve to clear the piston but it htting it i can see the valve marks.
Old Jan 5, 2008 | 10:07 AM
4g hatch's Avatar
Default Re: (gs1gsr)
what pistons does it have.
Old Jan 6, 2008 | 12:07 PM
gs1gsr's Avatar
Default Re: (4g hatch)
PR4 pistons but its funny under the PR4 it says 0.8 what in the hell is that never seen that before.
Old Jan 6, 2008 | 12:37 PM
pdotjones's Avatar
pics of said groove?
Old Jan 6, 2008 | 07:54 PM
gs1gsr's Avatar
Default Re: (pdotjones)
not sure how to paste pic on here so may not work let me know.
Old Jan 6, 2008 | 08:56 PM
sorrule's Avatar
Is the arrow pointing toward the crank pulley and is the IN on the Intake side? Was your head ticking before? Kinda weird though, seems like if the valves were kissing the pistons there's be more carnage instead of the perfect grooves. Ask the person you got it from what the hell he did.
Old Jan 7, 2008 | 08:19 AM
Golden Eagle's Avatar
Default Re: Valves hitting pistons (gs1gsr)
the valve reliefs on a ls piston are not big enough for vtec valves and will always hit. i sagest changing your pistons to itrs and that will solve your problem
Old Jan 7, 2008 | 05:40 PM
turboaap's Avatar
Default Re: Valves hitting pistons (Golden Eagle)
see if you can findout if the engin ever broke a timeing belt if it did then it mostlikely hit the piston. was the motor making any noise befor you took it apart?
Old Jan 7, 2008 | 05:52 PM
gs1gsr's Avatar
Default Re: Valves hitting pistons (turboaap)
timing belt was on when i got the motor and i never hear it run so not sure how it sounded or any thing. Its funny becasue its perfect and it dont look like any thing serious happen other than what you see on the pistons. But like Goldeneagle said maybe the reliefs are not big enough on the ls piston for the Vtec valves?
Old Jan 7, 2008 | 06:39 PM
turboaap's Avatar
just because the belt was on when you got it dosent meen it dident break a timeingbelt sometime in its life and hit the valves. the valve shouldent be that close to the piston. i would put it together and see if you can turne it over by hand ifso then it should be ok but you wont know till you start it up. goodluck
Old Jan 8, 2008 | 07:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboaap &raquo;</TD></TR><TR><TD CLASS="quote">just because the belt was on when you got it dosent meen it dident break a timeingbelt sometime in its life and hit the valves. the valve shouldent be that close to the piston. i would put it together and see if you can turne it over by hand ifso then it should be ok but you wont know till you start it up. goodluck</TD></TR></TABLE> the valves are that close to the pistons and if you use ls pistons this is what happens. i have seen this hundreds of times.
Old Jan 8, 2008 | 09:19 PM
gs1gsr's Avatar
Cool thanks you all for your help.
Old Jan 9, 2008 | 09:56 AM
no prob man anytime
Old Jan 9, 2008 | 10:26 AM
4g hatch's Avatar
you may be able to take a die grinder and open them up and see if that helps. i know people do it when the pistons are out of the motor but i dont know about in the motor,just have to be careful to clean up all the dust and shavings
also looks like there not hitting it much maybe you could get a thicker head gasket from cometic also. im trying to give you suggestions if its your daily driver and you need it running,but the best way exspecially if your gonna upgrade cams in tha future is to do what golden eagle said and swap the pistons
Old Jan 9, 2008 | 09:30 PM
gs1gsr's Avatar
Default Re: Valves hitting pistons (4g hatch)
Yea that the plan to change pistons. I was was j ust tripping out on that. I didnt know any thing about having smaller reliefs. Thanks for the help.
djteggy99
Mar 19, 2010 07:41 AM
1A4
Mar 28, 2008 01:18 PM
gs1gsr
Jan 13, 2008 09:20 AM
lyckaon
Nov 20, 2005 11:05 PM
smokinsi
Jul 25, 2004 05:51 AM
