Steering squeak problem
Old Jan 4, 2008 | 07:09 AM
Mr. Em1's Avatar
Default Steering squeak problem
I have a very annoying squeak that sounds like its coming from the rack. It makes the sound with the car on or off. I think there may be air in the power steering fluid system any other suggestion let me know., thanks for your help in advance. ( searched and didn't come up with a good answer)
oh yeah this is a 99 si
Old Jan 4, 2008 | 07:22 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Steering squeak problem (Mr. Em1)
if you thin you have air in it, a way to bled it is turn to full lock on one side(as far as the wheel will go) and turn it off. then do it to the other side to. go back and forth a few time's.
otherwise check your inner tie rod's and your outer one's. they might be damaged.
Old Jan 4, 2008 | 10:04 AM
Mr. Em1's Avatar
word thats a quality call, im pretty sure its just my inner tie rods, i changed the outer tie rods more recently the inners probably are stock ( 140k) lol
Old Jan 19, 2008 | 09:40 AM
Mr. Em1's Avatar
alright i've changed all the inner and outer tie rods and i still have the squeak no matter ho fast i am going. I think it is probably the seals in the rack are ****. My question is should i fix the rack or should i just replace it. Also is the Ex and si 96-00 the same rack that ould fit onto my 99 si?
Old Jan 20, 2008 | 08:57 AM
Mr. Em1's Avatar
ttt
Old Jan 20, 2008 | 09:29 AM
Boostless-Lude's Avatar
Default Re: (Mr. Em1)
i want to know also.
Can you fit the cx one on there too?
Old Jan 20, 2008 | 12:59 PM
Mr. Em1's Avatar
up ttt
crowscare
Dec 17, 2014 05:29 PM
snafu0072
Apr 23, 2012 10:50 PM
furiousbob
Mar 13, 2009 02:26 AM
vultron
Nov 11, 2004 07:05 AM
