high idle please help ..........
Old Jan 3, 2008 | 06:58 PM
slowB20ej8's Avatar
Default high idle please help ..........
just replaced my tps sensor and when i start it it idles hecka high around 2500 rpm checked my iacv the screw is all the way in
Old Jan 3, 2008 | 07:01 PM
z6hatchboy's Avatar
Default Re: high idle please help .......... (96lsivtech)
Is this during start up? Check the fitv.
Old Jan 3, 2008 | 07:03 PM
babyboy9o7's Avatar
check for vacuum leaks.
Old Jan 3, 2008 | 07:04 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: high idle please help .......... (z6hatchboy)
bro you have got to stop making these threads after each other .... the first three on the top are about the same thing...i've already told you where to go with this ...
Old Jan 3, 2008 | 07:31 PM
Throwdown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">take the iacv off and clean it out with brake cleaner ..also check it to see if it's working 12v power and a ground listen for a click (no click? replace it)...also check for vac leaks ,check the idle screw on the throttle body and make sure everything is plugged in where it should be...as far as the rad..have someone or you do a pressure check to see if it has any cracks good luck </TD></TR></TABLE>^^^like i stated before in the first of the 3...you should have a idle scew on the top of the throttle body......bro if your going to not go through with trying to figure this problem out with the help from me or anyone else on this forum ..then don't waste are time...your not even looking into what i'm trying to tell you HELP ME HELP YOU!!
Modified by Throwdown at 11:48 PM 1/3/2008
Old Jan 3, 2008 | 07:58 PM
slowB20ej8's Avatar
Default Re: high idle please help .......... (Throwdown)
na bro......i tried adjusting the idle screw on the throttle body and i pulled the iacv off again made sure the screw was in all the way and i also cleaned the iacv with carb cleaner still the same result the reason i put another post up is cause u aint the only person who works and hondas in the world there are other people believe it or not and i am open to anybodys input as long as they know what there talkn bout cause what ive tried so far hasnt gotten me to far.......
Old Jan 3, 2008 | 08:08 PM
Throwdown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsivtech &raquo;</TD></TR><TR><TD CLASS="quote"> i put another post up is cause u aint the only person who works and hondas in the world there are other people believe it or not </TD></TR></TABLE>no **** but why three threads in the matter of minutes from when i replied from your first one???thats retarded ..... *throws in the towel* hope you figure it out cause i'm done
Old Jan 3, 2008 | 09:39 PM
robzilla0589's Avatar
check to make sure that your vaccumes are routed correctly and also for the vaccume leaks
Old Jan 3, 2008 | 09:42 PM
if you dont have vaccume diagrams
you can find them at autozone.com
believe it or not
jus click the link
http://www.autozone.com/az/cds...s.htm
gsr96cx
Aug 3, 2008 04:54 PM
ED9man
Jan 10, 2007 07:13 PM
JDM90SiR
Jan 27, 2005 08:58 PM
Bigjussin
Mar 3, 2004 07:06 PM
rurkster
Nov 14, 2002 05:52 AM
