...: Few Head Gasket ?'s :...
Old Jan 3, 2008 | 04:16 PM
DCf4i's Avatar
Default ...: Few Head Gasket ?'s :...
Just a few questions before i tackle the d15 head gasket project . . .
1.) What all gaskets/ seals should I replace ?
- head gasket
- valve seals
- valve cover seal
- spark plug rings
- cam seal
- anything else ?
2.) Any reason not to use the Felpro gaskets from Autozone ?
3.) Anything else I'll need ie. oil change or spark plugs ?
I'll be using the Haynes manual. Any advice or tips would be appreciated.
Thanks
Old Jan 3, 2008 | 08:28 PM
DCf4i's Avatar
Default Re: ...: Few Head Gasket ?'s :... (DCf4i)
I'll probly end up getting the kit that also comes w/ the intake, and exhaust gaskets, and possibly the TB and water pump.
Anyone ? Just looking for a double check before I get into this ?
Thanks
Old Jan 4, 2008 | 07:10 AM
JOE BD-0's Avatar
I would use the factory head gasket upgrade kit. This new head gasket can be re used and the new style bolts have been re designed with spiral shafts to prevent stretching. Good Luck.
Old Jan 4, 2008 | 08:39 PM
DCf4i's Avatar
Default Re: ...: Few Head Gasket ?'s :... (JOE BD-0)
Thanks
Old Jan 4, 2008 | 09:21 PM
UfoTofU's Avatar
In for second opinions too....
91 CRX DX here, I'm looking to do a :
- Head Gasket
- Timing belt
- Waterpump
Probably should do cam seals, valve cover gaskets, intake / exhaust gaskets?
Old Jan 6, 2008 | 03:40 PM
DCf4i's Avatar
Default Re: ...: Few Head Gasket ?'s :... (UfoTofU)
I found it alot cheaper to get the Cam Seal, Valve Stem Seals, valve cover seal, and spark plug rings OEM from hondaautomotiveparts.com, for some reason autozone wanted $54 for the valve seals and they're only $1.03 a piece for OEM
I read something about the OEM head gaskets for our year cars not being as "good" so I went w/ the felpro from autozone, i'm not sure if the OEM one has been updated or if thats even true
GL
Old Jan 6, 2008 | 04:16 PM
Tippyman's Avatar
Well, the OEM headgaskets are fine, the only problem is that they are made of composite material, so when you have to change them there is alot of material to scrape off. Plus, they are not as strong when you start going forced induction.
I would just upgrade to an OEM D16Z6 or D16Y8 headgasket. They are three layer metal gaskets.
Old Jan 6, 2008 | 04:18 PM
chirp the 1-2's Avatar
yep the y8 oem headgasket is the way to go!
Old Jan 6, 2008 | 04:48 PM
fin781's Avatar
get the oem head gasket from a honda dealer. there around 60 but there like 4 layer metal or whatever. its a newer design than the cork crap. works very well
Old Jan 7, 2008 | 10:04 AM
DCf4i's Avatar
Default Re: ...: Few Head Gasket ?'s :... (fin781)
Alright, Good Stuff
has anyone tried to reuse the head studs ? or is that just a bad idea ?
Thanks Alot
Old Jan 7, 2008 | 01:41 PM
Tippyman's Avatar
It's OK to re-use headstuds such as ARP, but NOT ok to reuse headbolts such as OEM. They are called stretch bolts, and are one time use only.
Old Jan 7, 2008 | 01:44 PM
GSX 4G63T's Avatar
Default Re: ...: Few Head Gasket ?'s :... (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">It's OK to re-use headstuds such as ARP, but NOT ok to reuse headbolts such as OEM. They are called stretch bolts, and are one time use only.</TD></TR></TABLE>
You mean yield to torque bolts: one time use only, buddy.
xW01FxGANGx
Jul 17, 2014 06:33 PM
wittynamessuck
Honda Civic (2001 - 2005)
14
Oct 27, 2011 07:28 AM
djtony5
Nov 2, 2005 02:40 PM
mulin
Nov 3, 2004 09:25 PM
