Battery dies in 3-4 days :(
Old Jan 3, 2008 | 02:21 PM
gpdxtrm's Avatar
Default Battery dies in 3-4 days :(
I have a red top battery in my 91 CRX. I lost my license so it's been sitting in my garage. I've been doing work on it, so its been started and moved around almost everyday.But I went to start it today and it was dead. Its only been 3-4 days since I last started it. What could cause this? The battery is fairly new. Thanks
Old Jan 3, 2008 | 02:29 PM
Ermil's Avatar
Default Re: Battery dies in 3-4 days :( (gpdxtrm)
Have you done a draw test?
Old Jan 3, 2008 | 02:30 PM
AnonymousSquid's Avatar
sounds like your alternator is bad.
Old Jan 3, 2008 | 02:35 PM
x91crxsix's Avatar
Default Re: (AnonymousSquid)
get a volt meter and try the alternator , could also maybe be a bad ground or a small short somewhere...the ecu throwin any codes and does the battery light come on or stay on
gpdxtrm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">Have you done a draw test?</TD></TR></TABLE>
How do I do this? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x91crxsix &raquo;</TD></TR><TR><TD CLASS="quote">get a volt meter and try the alternator , could also maybe be a bad ground or a small short somewhere...the ecu throwin any codes and does the battery light come on or stay on </TD></TR></TABLE>
I'll test the alternator and grounds tomorrow. Its below 0 out, so i'll wait.
Old Jan 3, 2008 | 06:06 PM
nfereorhatch's Avatar
had a yellow top that did the same thing, had it tested and the battery was bad. mine was still under warranty so autozone just swapped it out.
Old Jan 3, 2008 | 06:49 PM
alscrx's Avatar
Default Re: Battery dies in 3-4 days :( (nfereorhatch)
Just have your charging system tested at a shop since your not sure on using a voltmeter. They can help you out
Old Jan 3, 2008 | 07:33 PM
grog's Avatar
Default Re: Battery dies in 3-4 days :( (alscrx)
I have one question for you. were you leaveing a door open over night? Ive done that and discovered that the seatbelts draw power when the door is open
Old Jan 4, 2008 | 03:29 PM
StorminMatt's Avatar
You may be starting the car every day. But are you REALLY running it long enough to make up for self-discharge? If the car is not being run sufficienty long to charge the battery, then you might want to put it on a trickle charger.
One more thing. The battery could be bad at this point in time. Lead-acid batteries do not like to sit in a discharged state, and will go bad if this happens for long periods of time. And a load test may not be able to determine a bad battery. It is entirely possible for a bad battery to be able to deliver a high current for a relatively short perod of time, yet go dead in a couple of days OR suffer from low reserve capcity.
Old Jan 4, 2008 | 04:01 PM
gpdxtrm's Avatar
Default Re: Battery dies in 3-4 days :( (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Just have your charging system tested at a shop since your not sure on using a voltmeter. They can help you out </TD></TR></TABLE>
I can do it. I just wasn't thinking draw test was the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">I have one question for you. were you leaveing a door open over night? Ive done that and discovered that the seatbelts draw power when the door is open </TD></TR></TABLE>
No, they were closed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">You may be starting the car every day. But are you REALLY running it long enough to make up for self-discharge? If the car is not being run sufficienty long to charge the battery, then you might want to put it on a trickle charger.
One more thing. The battery could be bad at this point in time. Lead-acid batteries do not like to sit in a discharged state, and will go bad if this happens for long periods of time. And a load test may not be able to determine a bad battery. It is entirely possible for a bad battery to be able to deliver a high current for a relatively short perod of time, yet go dead in a couple of days OR suffer from low reserve capcity.</TD></TR></TABLE>
I'll try trickle charging. The only thing is I don't have the reciept, which sucks.
crxma22
Honda Motorcycles
15
Dec 9, 2006 12:53 PM
95ejjj
Jan 8, 2006 05:44 PM
fanta!
18
Dec 8, 2005 11:52 AM
fanta!
Dec 7, 2005 10:52 AM
ownedbyvtec
Aug 24, 2003 01:18 AM
