13.7@104.26!
Made that run on dunlop SP Sport 185/65 R14s. 7psi boost, 30psi tire pressure.
Here is a breakdown.
60ft 2.24
1/8 8.974
MPH 80.97
1/413.717
MPH 104.26
I got the car tuned for 10psi as well. With a little more traction, and 10psi do high 12's sound possible???
60ft 2.24
1/8 8.974
MPH 80.97
1/413.717
MPH 104.26
Eau Claire, I live 45 minutes from there in Hudson, WI on the MN/WI border. I could give you a place to crash for the night before if you wanted. Tech check is pretty early.
[Modified by laughinXXX, 11:42 AM 6/29/2002]
b16a4me....that isn't a bad 60ft for me. Infact, it is the best 60ft I have EVER had.
Laughin, isn't Rock Falls up in Minnasota?
Nice time by the way......
That's a damn good 60' , considering you were on street tires set @ 30 psi. My best is a 2.1 on streets @ 20psi.......
Guess I am a good driver afterall.......
97 civic Hx full interior
b16a2 swap
Drag3 turbo
Hondata
and lots of other stuff.
That is a good time you have there pg_thao, and I see you are from Milwaukee? Let me know sometime when you are going to the drag strip again.
[Modified by HXMan, 6:11 PM 7/6/2002]
b16a2 swap
Drag3 turbo
Hondata
ok...check this out...i have a 4dr civic 91 w/crvtec pushing 211whp 158.4tq
now my ? is when i first ran the car i ran a 13.0 @ 105 other runs where around 13.0-5 but all at 104-05mph...i ran 24" slicks..then i changed them to 22" and my traps were like 99-103mph did i screw up by going to smaller slicks?
all u need is traction. thats a high 12 low 13 second trap speed. u need tires not traction bars or more boost. based on the 60, 1/8 and 1/8th trap speed, looks like the top end gears pull hard but u are lackin in the bottom end. 80 mph is decent but should b more around 84 but ur top end 3rd/4th gear must pull hard as hell. 104 is an excellent trap speed.
HXMan - you finally got the oil leak fixed?
this is just for reference to ur ET and trap speed HXman.
RT: didnt matter
60ft:1.970
330: 5.454
1/8: 8.355
MPH: 84.02
1000: 10.880
1/4: 13.004
MPH: 105.91
ur right there HXman. i hear awesome things about the new BFG force drag TAs. i love my NITTOS also. if u dont wanna break parts, try a pair of these. if u wanna really step up get axles and slicks.
RT: didnt matter
60ft:1.970
330: 5.454
1/8: 8.355
MPH: 84.02
1000: 10.880
1/4: 13.004
MPH: 105.91
I am thinking about a set of BFG force drag TAs. I don't want to go to slicks, and beefier axels. Breaking trannys is not up my ally.
I am more interested in what my car will run on the street, another reason to not get slicks. I don't participate in organized street racing, but if someone wants to run me stoplight to stoplight I am down.
kameleon23
Apr 26, 2006 10:47 AM
