Headlight Woes
Driver side wasn't working. I checked all the wires and redid some of them that looked iffy. I turned on the lights, the drivers side brights worked but the low beams didn't, Im assuming bad bulb. But then after they were on for about 2 minutes the drivers side just shuts off, not high or low beam. I get in the car and check them. I try both, neither works. I now notice that the high beam indicator doesn't show that the high beams are on, yet they/it was. Any help with this weirdness or what could cause it would be great.
Ps this is on a 98 ex.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vandersmissenc »</TD></TR><TR><TD CLASS="quote">in my car the fuse for the headlights is different than the dashlights and low beams and high beams also have different fuses.</TD></TR></TABLE>
They're different for the 6th gens too.
https://honda-tech.com/zerothread?id=1966666
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurtgen »</TD></TR><TR><TD CLASS="quote">ground?</TD></TR></TABLE>
check your ground ethan. on my buddies teg, his dash lights kept blowing fuses. turns out the jack *** who installed his stereo, left a hot wire stripped and it was grounding out, popping fuses. just check the simple stuff first. if you need anything, you know where i live.
p.s. when do i get to shoot the new ride?
Jimi Hondrix
Dec 20, 2016 04:10 PM
