gsr into 93 da
Old Jan 2, 2008 | 02:45 PM
droppedeg6hatch's Avatar
Default gsr into 93 da
so im swapping a b18c1 obd1 integra gsr motor into my 93 integra gs... i would like to keep stock mounts for now but which set do i use the stock da mounts are 14mm bolts (3) and the gsr has 2 17 mm bolts and 1 17mm stud- how do i get my stock mounts to work also there is a green plug on my stock b18a1 harness next to the oil sensor on the back of the block but my gsr does not have it- any ideas of what it is or if i even need it???
aim: jdm1piece
Old Jan 2, 2008 | 02:59 PM
projectTeG's Avatar
use the bracket off of your old engine
Old Jan 2, 2008 | 03:41 PM
HONDRETTI's Avatar
Default Re: (projectTeG)
what year motor are you swapping in? i think the green plug you are referring to is the engine oil temperature switch that connects to your radiator fan control mod. i think its only found on US integra models 90-93 and is part of the a/c system.
Old Jan 2, 2008 | 05:50 PM
Default Re: (HONDRETTI)
the part of the motor mount that bolts to the actual motor on the driver side has holes for a 14mm bolt (3) to be exact and my 1995 gsr motor has the same 3 holes but they are 17mm bolts and so the 14mm bolt holes on the stock bracket dont fit on the 17 mm bolts
Old Jan 3, 2008 | 07:47 AM
Default Re: (droppedeg6hatch)
bump
Old Jan 7, 2008 | 12:34 PM
Default Re: gsr into 93 da (droppedeg6hatch)
bump- tried drilling out the bracket today so the mount would slide over the studs- snapped 2 of the best bits made- what do i do??? need help asap
Old Jan 7, 2008 | 01:47 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedeg6hatch &raquo;</TD></TR><TR><TD CLASS="quote">the part of the motor mount that bolts to the actual motor on the driver side has holes for a 14mm bolt (3) to be exact and my 1995 gsr motor has the same 3 holes but they are 17mm bolts and so the 14mm bolt holes on the stock bracket dont fit on the 17 mm bolts</TD></TR></TABLE>
my 98 gsr block bolted that bracket fine
Old Jan 7, 2008 | 01:50 PM
be18see1's Avatar
pull the bracket off the b18c1, not the mount off the bracket. you probably need to take off the timing cover. i did this exact swap. youll need an aftermarket mount if you intend to run the hydro tranny, or some welding skills and a mill. dont make it harder than it is.
Old Jan 8, 2008 | 07:50 AM
so i should use the bolts that came of the b18a1 and thread them into the b18c1 holes?
Old Jan 8, 2008 | 06:22 PM
be18see1's Avatar
it doesnt matter, theyre just bolts. i think i personally just reused the b18c1's bc they were newer.
Old Jan 9, 2008 | 08:19 AM
Default Re: gsr into 93 da (be18see1)
solve the problem- brought the bracket to a local machine shop and they are boring (lol) the holes so the 17mm bolts fit
Old Jan 9, 2008 | 03:12 PM
be18see1's Avatar
you didnt need to do that. it could have been free.
Old Jan 9, 2008 | 03:21 PM
be18see1's Avatar
all you needed to do was take off the timing cover and take the bracket off the block.
Old Jan 9, 2008 | 05:09 PM
db1_jdm's Avatar
all u had to do is reuse ur b18a brakets and mounts
Old Jan 9, 2008 | 05:31 PM
be18see1's Avatar
Default Re: gsr into 93 da (db1_jdm)
thats what i told him over and over..
Old Jan 10, 2008 | 07:35 AM
ok- i am using the stock b18a1 bracket and mount and putting it on the gsr- but the bolts that hold the original gsr bracket to the motor were 17mm and the ones i took off the b18a1 were 14mm so the 17 mm bolts wouldnt fit through the holes on the b18a1 bracket- the whole time i was asking i understood what bracket to use just didnt know how to mount it- but i had a machine shop drill it out so the gsr bolts would fit- so were good now
Old Jan 10, 2008 | 04:28 PM
be18see1's Avatar
i wish i had a picture to show you. post a picture and ill show you. i want you to know for future reference im not trying to be an *** or anything.
Old Jan 10, 2008 | 04:30 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 &raquo;</TD></TR><TR><TD CLASS="quote"> i want you to know for future reference im not trying to be an *** or anything. </TD></TR></TABLE>
yes you are, don't lie
i mean you told the kid like what, 5 times?
Old Jan 10, 2008 | 07:09 PM
be18see1's Avatar
Default Re: gsr into 93 da (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
i mean you told the kid like what, 5 times?</TD></TR></TABLE>
1.) hes 4 years younger than you, thus, not a kid.
2.) no
Old Jan 10, 2008 | 07:28 PM
GRAF-FITI's Avatar
* B A N N E D *
2.) no</TD></TR></TABLE>
you're 5 years younger than me, kid
and you're soft....why don't you give the OP a
if you like repeating something over and over, then my bad, whatever floats your boat
Old Jan 11, 2008 | 01:11 AM
volcom40street2's Avatar
reference
Old Jan 11, 2008 | 06:09 PM
God-Driven's Avatar
If you are keeping the power steering system you are going to use the upper gsr braket and LS for the lower one.
Old Jan 20, 2008 | 05:19 PM
FYI motor is running in the engine bay- whether it was worth the 30 bucks or not- im trying to explain what was wrong as easy as possible- my gsr bracket off the motor used 17mm bolts- obviously the holes were drilled and tappen bigger at some point- the bolts that came off the bracket on the ls engine were 14's- you say use the stock b18a1 bracket- GOT IT but the holes on it are made to fit 14mm bolts not the 17mm i needed to use to bolt it to the gsr- problem solved no need to hate on me figured i could come and ask a question but everyone would rather bash me then help- so i did what i had to do- end of problem
digital sol
Jul 23, 2008 10:30 AM
I CRX I
11
Mar 23, 2007 11:35 AM
BLUE EH3
Dec 14, 2003 02:00 PM
LSturboHB
Aug 29, 2002 03:52 AM
