Help car shuts off.
Old Jan 2, 2008 | 11:14 AM
PuroMotor's Avatar
Default Help car shuts off.
Hey guys, well for the past few weeks my car has shut off on me a number of times. It seems to be an electricle problem. First my stereo goes out, then my tach drops down to almost 0 rpm. The headlights dim down. The car idles good even though the rpm drops but after a couple minutes the car just turns off. I checked the battery.. its good. The previous owner of the car relocated the battery to the trunk and he used some stereo fuses and terminals to do the power hook up. Do you guys think it might be that? Also he put in one of those anoying push buttom ignition starts. Sorry for the lack of information but I cant figure it out.
Thanks for your time.
Here are a couple of pics of that stereo setup.
Modified by PuroMotor at 12:28 PM 1/2/2008
Old Jan 2, 2008 | 11:31 AM
alscrx's Avatar
Default Re: Help car shuts off. (PuroMotor)
Does the car restart or does it have to be jumped???
Old Jan 2, 2008 | 11:34 AM
PuroMotor's Avatar
Forgot to mention that. After it shuts off it will restart after 10mins or so. But somtimes it wont. I had to push it out of a taco bell drive thru once. This seems to happend when I drive the car hard or when I bump up the music. Other than that it hasnt shut off.
Old Jan 2, 2008 | 12:27 PM
pdx_503's Avatar
Default Re: (PuroMotor)
Alternator
Old Jan 2, 2008 | 12:39 PM
alscrx's Avatar
Default Re: (pdx_503)
Have your alter checked. They can do a load test. Will prob have to be replaced. For your system buy a hi amp alter for like 130 on ebay instead of oem one
Old Jan 2, 2008 | 01:44 PM
PuroMotor's Avatar
Thanks alot for the info!! any other posiblities I should take into account?
Old Jan 3, 2008 | 09:22 AM
B16-CRX's Avatar
ckeck your wires and make sure they arent grounding. If i were you i would disconnect the stereo wires and see if that fixes it.
Old Jan 3, 2008 | 09:26 AM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdx_503 &raquo;</TD></TR><TR><TD CLASS="quote">Alternator</TD></TR></TABLE>
If the battery is fully charged and starts and the battery light is on. Your charging system is not working. have the belt tension checked and then alternator. good luck
bark3rk20
Mar 13, 2011 10:38 AM
G2_Fella
Aug 12, 2007 11:36 PM
krazy
20
Jun 5, 2003 12:52 AM
CRX A4
Jan 9, 2003 10:11 AM
jdmillusion
Aug 31, 2002 09:11 PM
