Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable?
Old Jan 2, 2008 | 09:21 AM
dpine's Avatar
Default Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable?
Is there any difference in length between the two B-pipes?
Old Jan 2, 2008 | 02:11 PM
DAP97SI's Avatar
I would say that the coupe one is shorter according to the diagram in http://www.hondaautomotivepart...+PIPE
Old Jan 3, 2008 | 05:19 AM
2khb's Avatar
Default Re: Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable? (dpine)
yes, the hatch's b-pipe is longer because the cat is on the exhaust manifold. The coupes the cat is underneath the so the b-pipe is shorter. You can use a coupes b-pipe on a hatch but you have to move the cat underneath the car or get a test pipe.
Old Jan 3, 2008 | 05:53 AM
RyanA's Avatar
Default Re: Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable? (2khb)
Even when you compare the DX coupe (which had the cat in the same spot as the hatches) the B pipe is a different setup completely. the hatch has a shorter wheelbase than the 2/4 doors do. So, in a nutshell, it is not a direct bolt on. You can use a coupe B pipe but you'd have to cut and weld on it to make it fit correctly.
tommy boy2
Nov 24, 2014 03:03 AM
Kaiyoken
May 4, 2008 06:46 PM
invisible
Feb 13, 2007 01:36 PM
mjrino
Feb 13, 2007 11:30 AM
Skeletor
Mar 31, 2005 06:44 PM
