Sometimes it works, sometimes it doesnt.. (themostat thermometer temperature gauge)
Old Jan 1, 2008 | 05:59 PM
Dense's Avatar
Default Sometimes it works, sometimes it doesnt.. (themostat thermometer temperature gauge)
My car is a 1990 Honda CRX Si.
The engine temperature in my gauge cluster seems to be malfunctioning.
Most of the time it just stays in the same position it is in when turned off. But sometimes it works. Ive checked all my fuses and everything seems to be operational. I have not taken any thing apart yet.
I was wondering where i should start, im not too good with electronics.
(honestly it scares the **** out of me.)
I apologize for the long topic title but i had trouble using the search function,
and i thought if we could figure this thing out together, it might help someone later with the same problem as me.
Thanks in advance.
Old Jan 1, 2008 | 07:45 PM
mike9571's Avatar
Default Re: Sometimes it works, sometimes it doesnt.. (Dense)
Possiblity of being one of these...
-Bad thermostat. 1hr or so to replace
-Gauge malfunction.
-Bad ground (once was my problem) Had to take cluster apart and re-solder ground
Old Jan 1, 2008 | 07:50 PM
Dense's Avatar
Default Re: Sometimes it works, sometimes it doesnt.. (mike9571)
I dont think it is a bad ground because everything else in the cluster is fine.
i will check the thermostat tomorrow.
Thanks for the reply!
Old Jan 1, 2008 | 07:53 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dense &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it is a bad ground because everything else in the cluster is fine.
Thanks for the reply!</TD></TR></TABLE>
Everything also worked in my case. It was a ground for the thermo gauge.
Just pick up a new thermostat its good for a tune up anyways.
Old Jan 1, 2008 | 07:54 PM
black0hatch's Avatar
if your thermostat was bad it would over heat. you should start with the easy stuff like making sure the plug for the temp sending unit is pluged in and its a good conection. i did a swap and that plug wasnt on all the way and my temp guage only worked when i hit a bump. its the single wire plug under the dizzy.
Old Jan 1, 2008 | 07:55 PM
gourley's Avatar
Same thing with me, was just a thermostat
Old Jan 1, 2008 | 07:57 PM
mike9571's Avatar
Default Re: Sometimes it works, sometimes it doesnt.. (black0hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">if your thermostat was bad it would over heat.</TD></TR></TABLE>
Not true at all. I just replaced my thermo becasue sometimes it would stick open not allowing to get to operating temp. It would do it randomly.
Old Jan 1, 2008 | 08:03 PM
Dense's Avatar
Ill head over to Autozone or Kragen tomorrow and pick up another one.
I should pick up a manual too while im at it. I really want to learn how to work on my car, and keep it maintained.
On a side note, what is a good manual to buy to learn how to work on these?
Old Jan 1, 2008 | 08:05 PM
mike9571's Avatar
haynes is good for a beginner theres also helms.
Dont forget to look into the FAQ's!!!! Also to search!!!!!
gourley's Avatar
HAYNES
Old Jan 2, 2008 | 07:46 PM
Rease3's Avatar
Default Re: Sometimes it works, sometimes it doesnt.. (gourley)
mine stays cold but when im idleing at a lite it will go back up is that still a thermo
Josephsnodgrass
Honda Civic (2006 - 2015)
Mar 2, 2017 01:57 PM
dglassmyer
Apr 27, 2010 08:14 PM
spider2465
Jun 8, 2007 06:44 AM
ilovemydc2
Nov 18, 2004 10:04 AM
Rhetoric
Sep 14, 2001 06:55 PM
