B18CR Axels, EK Civic Spindles
Old Jan 1, 2008 | 05:46 PM
OMGWTFBBQ!'s Avatar
Default B18CR Axels, EK Civic Spindles
So from browsing all over this site as well as a few others, I have seen hints at the 98+ spec ITR axels being 36mm, and the EK spindles are 32mm. I'm in the market for a B18CR, is there any easy/cheap way to temporarily solve this problem? The next upgrade I plan on buying is a 98+ spec ITR brakes/spindles/trailing arms/etc conversion, but on seeing the size differences, would I have to buy the conversion at the same time as the swap for the axels to fit? I would rather wait another month to have a running car than spend several hundred dollars on custom axels that I will use for a short time at best.
Help appreciated
Old Jan 1, 2008 | 06:02 PM
wicked_b16eg's Avatar
Default Re: B18CR Axels, EK Civic Spindles (OMGWTFBBQ!)
just use some GSR or ls or even si axles till you do your conversion
Old Jan 1, 2008 | 06:19 PM
OMGWTFBBQ!'s Avatar
Default Re: B18CR Axels, EK Civic Spindles (wicked_b16eg)
The GSR axels are the same size as the Type-R axels at the tranny/halfshaft? Are all Honda/Acura axels the same on the tranny side?
Old Jan 2, 2008 | 07:58 AM
OMGWTFBBQ!'s Avatar
Anybody else?
Old Jan 2, 2008 | 03:14 PM
Default Re: (OMGWTFBBQ!)
i know all b series axels are the same.. As for the type R im not sure though
Old Jan 5, 2008 | 06:33 PM
OMGWTFBBQ!'s Avatar
bump, anyone know about the type r axels? I dont want to be the first to figure it out....
Old Jan 5, 2008 | 06:37 PM
zerovandez's Avatar
JDM ITR axles are 36mm. All U.S. B series 95-UP are the same.
Old Jan 5, 2008 | 06:42 PM
OMGWTFBBQ!'s Avatar
Default Re: (zerovandez)
but what are my options for rolling on 32mm spindles? Are there axels that have the same tranny dimensions as the b18c5 with a 32mm outer?
Old Jan 5, 2008 | 06:46 PM
zerovandez's Avatar
Yes. Just use GSR axles.
Old Jan 5, 2008 | 06:47 PM
OMGWTFBBQ!'s Avatar
Awesome, thank you sir
jdmfamilia
Oct 4, 2011 12:23 PM
tesh
Jan 27, 2008 01:24 AM
K24EK
Feb 27, 2007 11:58 AM
206ek
Jan 30, 2005 05:05 PM
