turbo help
i want to get a trubo kit for my 2000 si b16. right now i have stage 2 cams, ITR head, honda ctr pistons .25 overbore, CTR ECU, exhaust clutch intake, and some more internal parts. im running pretty high compression now and want to know what i need for pistons and internals. i want to run around 300hp, any ideas for good kits?
First off, what is your compression ratio? That factor will determine how much power you can safely make on pump gas.
After that, you need to search. Your turbo setup is all based on your budget and goals. You can also build a setup by buying parts here and there from the Sponsor's Marketplace.
Search Here
Search Here
my compression is up around 11:5:1 ,
my budget is around 5 grand i found this kit that looks solid,
http://www.nolimitmotorsport.com/prod/HC25B2-X
let me know what you think
thanks
thanks
for the price, its not that great...check the Sponsor's Marketplace and you'll find something better for less $$
I run SLS stuff on my car and i'd definitely recommend them. SLS has a few "kits" they put together for different chassis and power goals.
You can PM PSI2HI or go to http://www.straightlinespecialties.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylevtec »</TD></TR><TR><TD CLASS="quote">what kind would be the best</TD></TR></TABLE>
What kind of what?
If you're talking about the brand of turbo, SLS includes a Precision unit with the kit. I've used Garretts on all of my setups without issue. Another great option from SLS is their shorty ramhorn manifold/dp/dump combo and then PM The Shodan and get a GT3255b like i run. Its a great setup for the street. If you check my sig, there is a link to my FOR SALE post of my GSR. It lists the parts i used in my setup and gives dyno numbers...feel free to bump
What kind of what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylevtec »</TD></TR><TR><TD CLASS="quote">my compression is up around 11:5:1 ,
thanks</TD></TR></TABLE>
For a couple hundred dollars more, you can get yourself a Peakboost turbo kit. It's pretty and works great. Comes with a Garrett 57trim w/.63a/r, Ramhorn Mani, 3"DP, TiAL 38mm WG, TiAL 50mm BOV, and all the other necessary peices.
I put down the number in my Signature with a 2.5 inch catback exhuast and a 9:1 CR with an extra safe tune for the winter. Even though that was on a Dynapack.
When I retune it, I'm shooting for 400whp, and it's only going to take 18-19spi.
With your compressoin ratio, you will be running verry low boost to hit 300whp.
WhoDoYouThink
Oct 4, 2005 01:02 AM
