need some help picking parts.
I been looking to get into the turbo scene. Im planning to boots my lsv and I want to make at least 600HP or close too 600. Planning to run skunk2 pro2 & head is already built n full p&p im Going to sleeve the block and planning to run a 6262 turbo or would I need something bigger? And if I do run the precision 6262 tubro any recommendation on compression ratio for the piston? & im going to be running 84mm.
And its gonna be a daily driven car but when I drive im gonna be on low boots.
Compression ratio depends on the fuel you plan to run, but generally you will want something between 9.5-10.5:1...any lower is wasteful. The turbo isnt my personal favorite, but will certainly do the trick.
Are the cams not a bit on the large side for that sort of setup? Maybe get away with a set of pro 1's or even a set of itr/ctr cams. Precision 6262 is a little over kill for 600hp.
I can get by with the pro 2 got a few buddys running them n I have the set already. And your saying 600HP a little too much for the 6262? You have a recommendation for a turbo?
