Rear Disc STICKS out and is not straight WHAT IS THE PROBLEM??
Old Jan 1, 2008 | 02:31 AM
88 civic ef's Avatar
Default Rear Disc STICKS out and is not straight WHAT IS THE PROBLEM??
I recent did a rear disc and it seem that the wheels in the rear sticks out more and is not riding straight. I am using blox conrol arms with 90 integra rear disc from the trailing arm to the toe adjuster. The wheel looks as i need a longer toe adjuster because it sticks in and its riding narrow alitte bit. WILL THE SPC TOE ADJUSTER HELP ?
Old Jan 1, 2008 | 05:01 AM
CRX Toad's Avatar
Default Re: Rear Disc STICKS out and is not straight WHAT IS THE PROBLEM?? (88 civic ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 civic ef &raquo;</TD></TR><TR><TD CLASS="quote"> 90 integra rear disc from the trailing arm to the toe adjuster. </TD></TR></TABLE>
That is your problem. You need to use your Civic "toe adjuster" (Compensator Arm) all you are using from the Integra is the trailing arm and disc brakes.
Read here
http://crf50.no-ip.com/fourthg....html
Old Jan 1, 2008 | 06:24 AM
88hbz6's Avatar
so your tires are ok up and down but angle a little from the back to the front.
Old Jan 1, 2008 | 04:20 PM
FSTVTEC's Avatar
Default Re: Rear Disc STICKS out and is not straight WHAT IS THE PROBLEM?? (88hbz6)
if its not riding straight and might feel wobbly check your rear trailing arm bushings also they might be shot. check to see if they are torn and dry rotted
Old Jan 1, 2008 | 04:32 PM
Targa250R's Avatar
be professional
You should not have used any other arms from the Integra other than the trailing arm. If you used the Integra toe compensator arm, that is your problem. Swap the Civic arm back on and get the car aligned.
If you did not swap any other arms except the trailing arms, then you have a bent trailing arm. You will need to swap the disc hub assemblies onto the Civic trailing arms, and install those instead.
Old Jan 1, 2008 | 04:41 PM
88hbz6's Avatar
Default Re: Rear Disc STICKS out and is not straight WHAT IS THE PROBLEM?? (Targa250R)
Will this cause new tires to wear in like 3 moths?
Old Jan 1, 2008 | 04:43 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88hbz6 &raquo;</TD></TR><TR><TD CLASS="quote">Will this cause new tires to wear in like 3 moths?</TD></TR></TABLE>
yes because your tires will be like this
Overhead view
Front
Rear
or
Overhead view
Front
Rear
Old Jan 1, 2008 | 04:52 PM
Targa250R's Avatar
be professional
An improper toe setting will chew up tires very quickly regardless of ride height, in addition to causing erratic handling.
Old Jan 1, 2008 | 06:00 PM
Default Re: Rear Disc STICKS out and is not straight WHAT IS THE PROBLEM?? (CRX Toad)
i didnt use my civic toe adjuster and threw it away with the drum brakes my rear tires are like this / \ but not that noticable so i need the civic TOE ADJUSTER ??
Old Jan 1, 2008 | 06:19 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 civic ef &raquo;</TD></TR><TR><TD CLASS="quote">i didnt use my civic toe adjuster and threw it away with the drum brakes my rear tires are like this / \ but not that noticable so i need the civic TOE ADJUSTER ??</TD></TR></TABLE>
Yes.
Old Jan 1, 2008 | 06:29 PM
88hbz6's Avatar
Put a civic toe agjuster asap, dont do wat i did brand new tires in 3 months.
Old Jan 1, 2008 | 07:39 PM
thanks guys so, my rear disc came with the toe adjuster and thought it would be fine to use the integra one but now i have to go back to the junkyard and look for the civic toe adjuster. Another question is that when i do fix the adjuster would my rim still stick out just alittle ?? i read some threads and they said DA rear disc sticks out alitle bit.
Old Jan 2, 2008 | 04:16 AM
CRX Toad's Avatar
Yes they will just a little.
Old Jan 2, 2008 | 04:31 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
they poke out the tinyest bit, but nothing overly noticable / horrible. I love mine.
brownsEF
Feb 27, 2010 07:01 PM
88 EF Hatch
Suspension & Brakes
Mar 3, 2009 06:22 PM
88 EF Hatch
Mar 3, 2009 10:12 AM
j spec
Suspension & Brakes
Apr 26, 2006 08:52 PM
soundbomber
20
Jan 20, 2004 02:29 PM
