no spark
well guys i have no spark at all. I have replaced my ecu(when i had a transistor was blown in it) i have replaced the cap, rotor, coil, plugs, and plug wires. i am still not getting any spark. My fuel pump primes so i don't think it is the main relay. When i had gotten the new plugs i pulled them to see if i had spark with them and when i did they sparked once and won't anymore. I have tested to see if i am still getting power to the dizzy and i am. i am stumped.
EDIT: i have all my grounds attached
Modified by mini-meEj1 at 3:52 PM 12/31/2007
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
no i mean have someone turn the ignition on try to start it and you check for signal from the ignition at the dizzy...you should have power and a signal
Modified by Throwdown at 8:30 PM 12/31/2007
also i don't know if you know it or not but any 92-95 dx dizzy will bolt right up to that y8 head and plug in to the harness perfect..its what i ran on my old y8 in my eg ..and they are everywhere works great bolts in perfect
yea already knew that i do have the d15b7 dizzy already bolted up one of my friends had built it for me but i dunno if he messed up wiring or w/e in it. but i already knew bout that dx dizzy lol
basically get a test light find your power then have someone turn the car over trying to start it and find the signal wire it should be next to the power but not for sure can't remember if you have signal replace the dizzy if not the problems in the ignition... its ok to ask questions bro we all started somewhere no one hatched out of there egg with a snap-on set and diagnostic skills
could be something to look into to PM if you can't figure it out and i'll try to help you as much as i can so we aren't post whoring it up
i'm sure he will update his problem when he finds out what it is....most people do when they start threads like this but whats the point of going back and forth on a thread with little details..i want to help but i'm not going to watch his thread all day and night
well guys found the problem it was my ignition harness..i need to head over to honda-tech:market place and try to find one. My engine is not turning over though being that i think i flooded it out tryin to turn it over so i will wait for a bit. but thanx for all your help.
Urban Business
12
Dec 22, 2002 12:28 AM
