A/C Evaporator pulled out now what
Anyone got any inside dash pics of a EG hatch without A/C? I would like to know what else i can remove and still have my heat work. Do i need to replace something? Pics below
Re: A/C Evaporator pulled out now what (Ep1dem1c)
you need to put your evaporator back in.. otherwise your blower cant connect to your heat to push the air through the dash...
Re: A/C Evaporator pulled out now what (boostedsingle)
so can i just gut the inside of the evaporator and use the black plastic around it? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsingle »</TD></TR><TR><TD CLASS="quote">you need to put your evaporator back in.. otherwise your blower cant connect to your heat to push the air through the dash...</TD></TR></TABLE>no you don't you just need the duct from a DX that didn't have A/C. or you can take the core out of the unit you have already and try to seal it up, but the DX duct is best and brand new like 40$
Re: A/C Evaporator pulled out now what (VRD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD »</TD></TR><TR><TD CLASS="quote">why dont u just leave it in?</TD></TR></TABLE>
I am doing a wiretuck. A/C was removed a long time ago by previous owner. I dont want any A/C lines left so if i remove the A/C lines the evaporator is still there.... hope that explains it. The plug i dont need.... the hole is being welded shut.
Re: A/C Evaporator pulled out now what (Weak!EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weak!EG »</TD></TR><TR><TD CLASS="quote">you need to put your evaporator back in.. otherwise your blower cant connect to your heat to push the air through the dash...</TD></TR></TABLE>
Can someone please confirm that the size of the 2 screws that hold the evaporator in place are 6 mm and 1.o pitch? Lost the original screws and I'm having a hard time putting mine back in. TIA
onekoop
01-02-2007 01:08 AM
DC4_MADMAN
10
08-15-2005 03:03 AM
