How can I calibrate the VSS for the size wheels/tires I'm running?
Maybe your right I don't know.
There should be because when you change wheels and tires the size could be different.
After it can't be changed (with oem **** anyways) check out this website to see how much of a diference the new rim/tire combo is going to matter http://www.miata.net/garage/tirecalc.html
the only vehicles i kno of that u can calibrate the factory computer for change in wheel size are chryslers. def not hondas.
Wow lots of replies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja396 »</TD></TR><TR><TD CLASS="quote">After it can't be changed (with oem **** anyways) check out this website to see how much of a diference the new rim/tire combo is going to matter http://www.miata.net/garage/tirecalc.html</TD></TR></TABLE>
Thanx Kuja396 for the link it helps me get a more accurate detail on the difference. I actually thought it was 5 mph off but its not off as much as I thought.
I was basing my calculations by the speed signs that show mph. So I think those radars in the signs are inaccurate, but that doesn't surprise me
Peace
Happy New Year to all at H-T
Peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">What size tires are you running?</TD></TR></TABLE>
205 40 16
I think I should go 205 45 16
Im gonna play with the sizes on that website kuja posted right now. I'll let yawls know what I find.
Yeah, next time I'm going with 205 45 16
This is what the tire/rim calculator tells me.
185/65-14 being my stock sizes. You can see there is a much bigger difference with the 40 series then the 45 series tires.
(Comparison with my current setup)
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
185/65-14, 4.7in, 11.7in, 23.5in, 73.7in, 859, 0.0%
205/40-16, 3.2in, 11.2in, 22.5in, 70.5in, 898, -4.3%
(Comparison with 45 series tires)
185/65-14 4.7in, 11.7in, 23.5in, 73.7in, 859, 0.0%
205/45-16 3.6in, 11.6in, 23.3in, 73.1in, 867, -0.9%
Once again thanx Kuja.
EDIT:
P.S. I hate when you post some thing how you want, then once you post it squishes words all around.
EDIT:
taimysho0
31
Jun 27, 2008 09:36 PM
PrimeElement
Oct 19, 2007 03:10 PM
2K_TEG
59
Jun 8, 2004 06:46 AM
calibrate, calibrating, calibration, civic, difference, honda, impreza, ratio, recalibrate, sensor, speed, vehicle, vss
