Need help with CEL
Old Dec 31, 2007 | 11:30 AM
rarrior23's Avatar
Default Need help with CEL
Just did a CEL check, I've got five problems:
electrical load detector
knock sensor
primary O2 sensor heater
secondary O2 sensor heater wires
fuel tank pressure sensor
Anybody know what I need to do to fix these?
Old Dec 31, 2007 | 11:34 AM
crazyguy's Avatar
Default Re: Need help with CEL (rarrior23)
what kind of engine or swap are u running. for the o2 sensors. just replace them with new ones. for the knock sensor, u can bypass it or get a chipped ecu.but again, it depends on the engine and ecu u are running
Old Dec 31, 2007 | 11:41 AM
rarrior23's Avatar
Default Re: Need help with CEL (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">what kind of engine or swap are u running. for the o2 sensors. just replace them with new ones. for the knock sensor, u can bypass it or get a chipped ecu.but again, it depends on the engine and ecu u are running </TD></TR></TABLE>
As far as I know, stock ECU, and the engine's a D16Y8.
Old Dec 31, 2007 | 11:45 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rarrior23 &raquo;</TD></TR><TR><TD CLASS="quote">
As far as I know, stock ECU, and the engine's a D16Y8.</TD></TR></TABLE>
knock sensor CEL only comes on when ECU detects excessive shake/vibration from engine.are all your motor mounts good ? and fuel tank pressure sensor is a rare CEL, i guess check the wires and maybe simply replace the sensor
Old Dec 31, 2007 | 11:50 AM
rarrior23's Avatar
knock sensor CEL only comes on when ECU detects excessive shake/vibration from engine.are all your motor mounts good ? and fuel tank pressure sensor is a rare CEL, i guess check the wires and maybe simply replace the sensor</TD></TR></TABLE>
Haven't checked the motor mounts but a guy at an auto-cross a while back told me the bushings were going out and that I should replace them. I'll probably end up replacing all the sensors that are bad since that's the easiest way to go about it. Thanks man.
Dstaks716
Oct 16, 2010 09:07 PM
tommy.
12
Jan 3, 2007 11:51 AM
Casual Gcode1
Nov 14, 2006 09:33 PM
njcrxsi
Jul 24, 2006 08:16 AM
racingant
Sep 10, 2005 05:34 PM
