skunk2 lowering springs, which ones go in the front and which go in the rear
i recently purchased some skunk2 springs for my ef. then i putt them on i assumed that the bigger springs went on the front and the smaller goes on the rear. but once i got the cr down on the wheels, the front seems to be a lil tucked and the rear is high. there where no instructions and nothing said which was for the front and what was for the rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazen_angles »</TD></TR><TR><TD CLASS="quote">its backwards the tall ones goes in the back</TD></TR></TABLE>
+1
+1
I just purchased these springs too.
do the fat wide ones go in the rear?
This one says they go in the front
https://honda-tech.com/zerothread?id=2127586
This one says they go in the rear?
https://honda-tech.com/zerothread?id=2148398
thanks
thanks
the fat wide ones go in the rear! the skinny ones go in the front. i had it backwards ar first and my car was sitting like a street rod low in the front high in the back. i switched them around and the car sits right. plus, if you try to put the big ones in the front you will see its a real tigh fit.
THE FAT ONES GO ON THE REAR THE SKINNY ONES GO IN THE FRONT!!!!!!
buymesomedunks
Suspension & Brakes
Jul 3, 2010 12:38 AM
tekturbo
Suspension & Brakes
10
Feb 20, 2008 08:22 PM
RACEPAK
Apr 21, 2006 04:51 AM
Solracer
22
Nov 3, 2004 02:47 PM
