new system draws alot of current help to keep the volts up ?
Old Dec 30, 2007 | 08:58 PM
blackccoupe's Avatar
Default new system draws alot of current help to keep the volts up ?
i was thinkin the big three and a bigger alternator now with these 2 being done would i need a capacitor at all the amp is a jensen 1300 watt <500> rms and 2 mb quart 12's let meknow guys
Old Dec 31, 2007 | 12:42 AM
8520's Avatar
Default Re: new system draws alot of current help to keep the volts up ? (blackccoupe)
No, you wouldn't.
I won't be running a cap on my 1400rms system.
Old Dec 31, 2007 | 04:54 AM
sqsi's Avatar
X2 No cap needed
Old Dec 31, 2007 | 08:06 AM
fcm's Avatar
fcm
Old Fart
Ditto both the above, if alt. can supply the demand a cap is not needed. 94
Old Dec 31, 2007 | 11:42 AM
Khrondor's Avatar
http://verizonsupersite.com/4alterstartcom/door/
Try these guys. Ive heard they offer a good product for the price. I also called the guy and he can usually go bigger if you really need it.
Old Jan 2, 2008 | 11:57 PM
dynimitejack's Avatar
Alt fo sho
Old Jan 8, 2008 | 06:59 PM
Default Re: (dynimitejack)
will a alt. def. take of this problem, also i am runing 8guage wiring to amp is that enough and when i run a new wire form the alt to the battery what size fuse should i put in line
lrcrx90
Audio / Security / Video
Aug 29, 2008 01:29 PM
doubledee
Jul 30, 2008 12:15 AM
burtonzt
Dec 27, 2007 05:25 AM
LAOS
Oct 18, 2005 09:48 AM
CrazyModGSR
24
Jun 11, 2004 11:17 PM
