Help ... did swap and car wont start!
Old Dec 30, 2007 | 08:41 PM
1BADEGDC2's Avatar
Default Help ... did swap and car wont start!
just put a d16y8 into my 92 vx hatch ...it has a p28 chipped ecu ... the car has spark, and fuel, it does crank, but i dont know why it wont start ... anybody suggest anything?? thanks for all your help ... brian
Old Dec 30, 2007 | 08:51 PM
wicked_b16eg's Avatar
Default Re: Help ... did swap and car wont start! (1BADEGDC2)
if it has fuel and spark but wont start then there is a major problem going on
Old Dec 30, 2007 | 09:08 PM
1BADEGDC2's Avatar
haha, well it had some zex spark plugs ... could i assume maybe that it had nos at one time and something went wrong?????
Old Dec 31, 2007 | 12:37 PM
1BADEGDC2's Avatar
TTT
Old Dec 31, 2007 | 01:37 PM
DA_9's Avatar
Default Re: (1BADEGDC2)
try moving ur dizzy....first make sure ur not using a vtec dizzy, then loosen, dont take them off, just loosen the bolts on it, try advancing and then retarding the dizzy. I remember when i did my swap i thought i had timed it correctly following that i advanced the dizzy and boom it started (i had the SAME exact symptoms as you), later on i retimed it and found that for whatever reason after advancing the dizzy all the way i was only off by like a degree or somethin. Worth a shot.
much luck
Old Dec 31, 2007 | 03:13 PM
1BADEGDC2's Avatar
thanks, ill give it a try
Old Dec 31, 2007 | 03:20 PM
BlackBeastEK's Avatar
make sure your sparkplug wire are in the right order on the dizzy thats probably what the problem is!!!
Old Dec 31, 2007 | 05:54 PM
1BADEGDC2's Avatar
no, i already did that ... there in the right order
Old Dec 31, 2007 | 06:15 PM
z6hatchboy's Avatar
Timing off? If your getting everything needed then theres only so many things it can really be i think.
Old Dec 31, 2007 | 06:41 PM
jdmhatch1's Avatar
Default Re: (DA_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_9 &raquo;</TD></TR><TR><TD CLASS="quote">try moving ur dizzy....first make sure ur not using a vtec dizzy, then loosen, dont take them off, just loosen the bolts on it, try advancing and then retarding the dizzy. I remember when i did my swap i thought i had timed it correctly following that i advanced the dizzy and boom it started (i had the SAME exact symptoms as you), later on i retimed it and found that for whatever reason after advancing the dizzy all the way i was only off by like a degree or somethin. Worth a shot.
much luck</TD></TR></TABLE>
The distributors are teh same vtec or non vtec
Old Dec 31, 2007 | 08:22 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: (jdmhatch1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatch1 &raquo;</TD></TR><TR><TD CLASS="quote">
i think that you are wrong on this one.
Old Dec 31, 2007 | 08:33 PM
yoffer's Avatar
Banned
Default Re: (DA_9)
Maybe its just me but a y8 is vtec, so why would you want to be using a non-vtec dizzy?
Old Jan 1, 2008 | 12:55 PM
1BADEGDC2's Avatar
doestnt matter, im gettin spark, isnt that all i need from the dizzy? im using a z6 dizzy, i just replaced the internals on the dizzies
heyitzspikey
16
Jan 16, 2009 06:38 PM
unrealgtx
Sep 20, 2007 08:16 PM
ilovejdmhoes23
Jan 18, 2007 11:30 PM
genop
Nov 23, 2002 08:20 AM
