Just got my B18B1 block back from my mechanic.. how do i identify it's year/vin/theft status?
Old Dec 30, 2007 | 12:06 PM
Neptronix's Avatar
Default Just got my B18B1 block back from my mechanic.. how do i identify it's year/vin/theft status?
Yeah.. so i just got my motor back from the guy who was going to do my swap, but doesn't have time to do it.
There seemed to be some confusion on what year the engine came from.. it's either a 1996 block or a 2000.. but i can't find a VIN on the block. should there be one stamped on it, or attatched elsewise?
Or are there any other markings on the block i could use to find out what year this motor is..
Old Dec 30, 2007 | 12:14 PM
Crx Jimmy's Avatar
Default Re: Just got my B18B1 block back from my mechanic.. how do i identify it's year/vin/theft status? (N
the head has a mark above the exhaust manifold/header, if the stock exhaust manifold is on its hard to see with the stock heat shield on. It should look like a circle around 9/6 if its a 1996 , sometimes the mark is cockeyed or turned. it should also have a vin tag near the oil pan on the front(exhaust side) of the motor
Old Dec 30, 2007 | 12:50 PM
Neptronix's Avatar
the markings are as follows:
on the head:
9/4 /8 3/0 0/6
to the left of the four circles ( above ), there is Hm, and on the right, it says PR4-4
on the left side of the block, towards the transmission, it says:
A409020157
the stamped engine code is B18B1
right below that, it says 2318005. the '00' seems to be in a bolder font than the rest of the characters.
there is nothing in that blank space above the oil pan.
The flat area looks like the rest of the engine... kind of textured.
the curvy area towards the left ( transmission ) is smoother.
argh.
Old Dec 30, 2007 | 01:06 PM
black0hatch's Avatar
its a 94. wouldnt a 2000 be a b18b2?
Old Dec 30, 2007 | 01:16 PM
Neptronix's Avatar
you sure about that?
Luserkid's Avatar
You have a 94 motor that came from a 95 model integra (motors before cars). If you ever plan on BARing the car it wont pass due to this as well. Also if you paid for a 00 you just got ripped off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">its a 94. wouldnt a 2000 be a b18b2?</TD></TR></TABLE>
I believe there is only B18B1, no B2. Other LS's are B18A1, B18A and B18B
Old Dec 30, 2007 | 01:29 PM
Neptronix's Avatar
ARGH...
should there be a VIN on this?
I paid $1000 for trans, ecu, and motor..
I wonder if i could get any part of my money back...
I knew some **** was up.
Old Dec 30, 2007 | 03:11 PM
Neptronix's Avatar
and... is this block worth anything? :/
Old Dec 30, 2007 | 04:14 PM
Luserkid's Avatar
If you pull the motor and sell it youll make your money back. If not then you have a good motor (unless there is problems with it). There wont be any VIN on OBD1 motors, In 1996 they desided to put VINs on there motors. Although this is only in America of course, in Japan they had no VINs on OBD2 motors. But i think 01 and up they started putting them on again.
Old Dec 30, 2007 | 04:16 PM
i_am_a_black_man's Avatar
post pics of the engine and tranny
Old Dec 30, 2007 | 04:21 PM
Neptronix's Avatar
Thanks luserkid. your help has been priceless.
black man: i am in the middle of moving and have no idea where my camera is.. so.. later.
jimmy051702
Oct 16, 2011 09:37 PM
junior_tm
Mar 30, 2009 06:07 PM
dynamo
Jun 26, 2005 11:30 AM
Kavehman
Mar 17, 2005 07:17 AM
blackANESE
Feb 21, 2002 09:08 AM
