is d16y7 worth turbo charging for lil more power???????
Old Dec 30, 2007 | 11:31 AM
rhdekhatchie's Avatar
Default is d16y7 worth turbo charging for lil more power???????
just wondering i want a lil more power and to know itf something does go wrog i dont have to spend alot of money on another motor or to rebuild. just want opinions on turboing one, thanks
Old Dec 30, 2007 | 11:54 AM
ke98248's Avatar
Default Re: is d16y7 worth turbo charging for lil more power??????? (rhdekhatchie)
If you want a little more power, pop in a 25 shot of nitrous and call it a day after tuning.
If you want signifcant power increases, turbo, after doing a leakdown and compression test on the motor to see how "healthy" it is. You can turbo your car, tuned and chipped for ~ $2,500
Old Dec 30, 2007 | 11:55 AM
97Ej6mike's Avatar
Yes, a D16y7 on boost, if done properly with the right parts, installation adn even tuning, can be fast. Keep in mind, finding the proper parts and paying for correct tuning is crucial to the lifespan of a motor. If you get legit parts and install them correctly, your motor will last in the long run. If you buy cheap parts, just keep in mind that you get what you pay for. Steer clear of Ebay brand turbos and manifolds.
Edit: Turbos dont add a "lil" amount of power, they add (when done properly) a large amount of power. A turbo would easily double your Y7's WHP output.
Old Dec 30, 2007 | 12:17 PM
Lasty K's Avatar
Boosting the y7 is worth it. You can make 200hp easy and still run reliable. OF course, people underestimate a good tune, get it tuned and you're set. As for blowing the y7, it's around 300-400 for a replacement swap. No biggie IMO.
Of course, that is all IMO.
Old Dec 31, 2007 | 09:42 AM
Default Re: is d16y7 worth turbo charging for lil more power??????? (ke98248)
thanks guys i appreciate it
Old Dec 31, 2007 | 09:45 AM
Cln94EG1's Avatar
If your going to boost it I would Change out the Rods thats the weak link to single cams
prox25
Oct 26, 2009 01:48 PM
integrals957
May 31, 2006 10:35 AM
SiRkid
Feb 13, 2003 01:07 PM
InfamousRS
Jan 16, 2002 06:17 PM
speedymon
Dec 28, 2001 02:19 PM
