steering noises
Old Dec 30, 2007 | 10:53 AM
brian_98EK's Avatar
Default steering noises
hey ever since i got my car back i have realized that whenever i turn my steering wheel my car makes "noises" from the front. its not a rubbing noise. so i checked my PS fluid and its full. but maybe should i just change it. my car turns fine but that noise is driving me crazy.
and answers/ advice is appreciated
Old Dec 30, 2007 | 11:19 AM
z6hatchboy's Avatar
If its full on fluid, you may try flushing it, but you may need a new p/s pump soon.
Old Dec 30, 2007 | 11:32 AM
TurboEK9Coupe's Avatar
Default Re: (z6hatchboy)
You might have some air in the system. I had bought a PS pump from a 00 SI. I installed it in the car and every time I would crank the car up and let it run, the fluid would just boil over. I could never figure out what was wrong with it until one day I had noticed that one of the bolts was missing that holds the pump together. I never would of thought that would cause this problem. What was happening was the bolt being missing was causing an air leak which in turn was causing sever cavitation. Put a new bolt in and has been working ever since.
Old Jan 1, 2008 | 11:16 AM
brian_98EK's Avatar
ok ill try flushing it but if you dont know i just got my whole front end fixed form an accident. so do you think it just might be damaged from that? any idea where i can get one or how much they cost?
Old Jan 1, 2008 | 11:52 AM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: (brian_98EK)
It could be your axels. Check to see if the boot is ripped.
Old Jan 2, 2008 | 06:00 PM
brian_98EK's Avatar
Default Re: (PinoyDelSol)
good point. thanks alot guys
Old Jan 3, 2008 | 09:18 AM
austinkli's Avatar
if your fluid is full and clean it could be the axel or your tie rod. the inner tie rod tends to make a nasty little noise when it goes bad.
bestofthe80s
May 30, 2017 09:57 PM
SilverEK96
Jan 27, 2014 04:39 AM
kovachki
Jan 7, 2012 03:11 PM
questseek
Mar 6, 2010 09:32 PM
djdownfawl
Mar 31, 2008 10:17 AM
