d16y7 turbo question need help???
when you turbo charge a d16y7 the stock exhaust manifold has the catalytic converter on the manifold itself. when i install my turbo manifold what do i do with the secondary o2 sensor that runs on the other side of the cat? i know i can plug one into my downpipe my question is do i have to get a cat. from like a EX model and run it inline with my exhaust and put a 02 bung into the piping after the cat so i can plug it in and not get a check engine from not hooking it up? any help with this problem is appreciated, i just want a lil extra added power to my cr not anything crazy just a lil boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdekhatchie »</TD></TR><TR><TD CLASS="quote">when you turbo charge a d16y7 the stock exhaust manifold has the catalytic converter on the manifold itself. when i install my turbo manifold what do i do with the secondary o2 sensor that runs on the other side of the cat? i know i can plug one into my downpipe my question is do i have to get a cat. from like a EX model and run it inline with my exhaust and put a 02 bung into the piping after the cat so i can plug it in and not get a check engine from not hooking it up? any help with this problem is appreciated, i just want a lil extra added power to my cr not anything crazy just a lil boost</TD></TR></TABLE>
Just get a cat off of an EX or something, and bolt it to an EX downpipe - you might have to cut down the exhaust a bit and put a new flange on it, but it should work fine.
sidewayz2013
Aug 27, 2014 12:27 PM
TooManyTickets
Dec 23, 2007 09:26 PM
projectpd
24
Feb 8, 2007 12:48 PM
