what kind of sub should i use with this amp?
just got this amp for a present and was wondering what kind of sub would be sound good with it. not really sure on my budget. just want some ideas on what should i get.
here's the link to the amp i got http://www.rockfordfosgate.com...tatus=
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Too many diffrent options. It depends on what your trying to do and your budget. What kind of car and sound are you trying to get?
One of these should do the trick... http://mobile.jlaudio.com/prod..._id=5 the box for it will depend on the kind of sub bass you want.
This is the easiest way to get it, stupid loud... http://mobile.jlaudio.com/prod...d=189
Also available in a sealed box for tight accurate sub bass... http://mobile.jlaudio.com/prod...d=302
94
94
Digital Designs have some impressive subs. You can get an amazing amount of bass from two of their 1508's (8" woofer) in a relatively small ported enclosure. Check out ddaudio.com and you can even read some stuff on the soundpressure.com forum. I heard a full size toyota truck with four of them in it at SEMA this year and it was amazing. They take 450w rms and 1800w peak
I just recently installed a single 1508 in my truck and people cannot believe it is a singe 8" woofer. I need to play around with port tuning some to see if I can get it to play a little lower. Only available in a 4 ohm coil, so you will have to do multiple subs to get the load you'll need for that amp. 3 of them will amaze you.
You will have to check your localJL Audio dealer for pricing.
You can get an idea here... http://search.ebay.com/JL-Audi....m120
But only buy from an authorized JL Audio dealer, only way to be sure you are getting the real thing.
94
94
